| Cadillac Seville / Cadillac Eldorado Forum Forum for discussions regarding the past Seville and Eldorado. | Cadillac Forums: Ranger, Pros.. One more Question.
04-09-08, 08:17 PM
| | Cadillac Owners Member Cadillac(s): 98 Cadillac STS | | Join Date: Dec 2007 Location: Mass. | | | Ranger, Pros.. One more Question. Hi Ranger and all the Pros out there,
I got the spark plugs and wires from rockauto delivered today and I am going to swap them out tomorrow. Read numerous posts and think I got it etched into my mind. Friend is bringing over the torgue wrench and I have everything ready to go. He is also going to bring over his Ramps and while I had the car up I wanted to take a look at something else. I think I read through every post today regarding the oil leak issue (took Hours and hour) What I got from it was it that there is a possibility it is a few easy fixes (cooler lines and so forth) or else it may be something much bigger that it not worth removing the engine for. Can you guide me through checking out the different possibilities to pinpoint what is leaking. I get the small drops under the car and when underneath the oil pan is usually oily and grimey. No noticably burning oil smell. That would be great! Also do I need a special tool to swap out the fuel filter or can I follow the thread with the guy with the 02 SLS. I have a 98' Guys, I really apprieciate the help and input.
Thanks,
Greg |
04-09-08, 08:26 PM
| | Cadillac Owners Connoisseur Cadillac(s): 98 Seville SLS *Lord Vadar* | | Join Date: Mar 2005 Location: DFW Texas Age: 23 | | | Re: Ranger, Pros.. One more Question. Best places to find the oil leak is where the lines go into the radiator and the oil pan bolts. Fuel filter should be pretty straightforward, just a couple of wrenches. |
04-09-08, 09:31 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Ranger, Pros.. One more Question. Not much I can add. |
04-09-08, 11:30 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2001 STS | | Join Date: Oct 2003 Location: Ontario | | | Re: Ranger, Pros.. One more Question. I would chance to guess, that if the oil pan is very coated, then that would be the first place to look.
Are you going through more oil than you should ? And are there oil patches under your car, below the oil pan, where you park it ?
If so. I would guess oil pan gasket. |
04-09-08, 11:58 PM
|  | Cadillac Owners Member Cadillac(s): 2001 Cadillac DTS, 2006 Cadillac SRX | | Join Date: Dec 2006 Location: New Jersey Age: 37 | | | Re: Ranger, Pros.. One more Question. Majority of the times it's the lower crankcase. But, check your oil pressure switch also which is on the oil filter adapter. |
04-10-08, 11:17 AM
| | Cadillac Owners Member Cadillac(s): 98 Cadillac STS | | Join Date: Dec 2007 Location: Mass. | | | Re: Ranger, Pros.. One more Question. So the lower crankcase and the oil pan gasket are the two possibilities that it probably isn't worth fixing because of the cost, correct? That is why I what to go under there tonight and try to pinpoint the problem. So I should check where the cooler lines go into the radiator, the oil pressure switch and possibly the oil pan bolts and those are more doable if that is the problem? How can I tell if the oil pressure switch is bad? |
04-10-08, 12:29 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Ranger, Pros.. One more Question. If the switch is very wet then it is likely leaking. |
04-10-08, 01:01 PM
| | Cadillac Owners Member Cadillac(s): 98 Cadillac STS | | Join Date: Dec 2007 Location: Mass. | | | Re: Ranger, Pros.. One more Question. And the switch is up near or behind the OIl Filter? |
04-10-08, 04:03 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Ranger, Pros.. One more Question. It's on the oil filter adapter. Look for the electrical connector. |
04-10-08, 08:32 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2001 STS | | Join Date: Oct 2003 Location: Ontario | | | Re: Ranger, Pros.. One more Question. If its the oil pan. Chances are that tightening the bolts wont fix it. Am not 100 % sure. But believe that they need to be torxed just like a tranny pan. Attempting to tighten up could result in the need to fix the gasket immediately. |
04-11-08, 08:23 AM
|  | Cadillac Owners Enthusiast Cadillac(s): 90 Eldo -SOLD-, 98 ETC -SOLD-, 86 XR4Ti Track Car, 07 Ranger | | Join Date: May 2004 Location: Atlanta, GA Age: 27 | | | Re: Ranger, Pros.. One more Question. I'd inspect (as mentioned before) your 2 oil cooler lines but u need to do this with the car running while there's some oil pressure to watch it seep, weep, or spray, these are usual culprits as the bottom return line uses a plastic clip inside the metal housing which can degrade/stretch/crack over time alowing oil to run down the line and onto the front subframe which can then travel to anwhere the wind takes it including your oil pan. Also, check your valve cover gaskets and spark ring o-gaskets, if you have ecessive oil buildup around the valve cover bolts it's probably time to change the gaskets. Then start worrying about half case seal and oil pan gasket leak. The half case seal is a biggie, requiring engine removal, oil pan gasket can be repairable in the car, it's just tricky and more of a small hands/acrobatics act. Goodluck! | | Cadillac Discussion Tools | | |
Censor is ON | | | |
