| Cadillac Seville / Cadillac Eldorado Forum Forum for discussions regarding the past Seville and Eldorado. | Cadillac Forums: Eldorado 1999 Water passenger side carpet
04-07-08, 09:26 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Eldorado 1999 Water passenger side carpet Hello,
we own a Cadillac Eldorado 1999. Yesterday we noticed (especially me) that water poured into the passenger side coming from underneath the dashboard. That only happens when the AC is on and when accelerating or driving around a corner. You can see the water pouring on to the carpet. Its not coolant from the engine (I hope), its clear water. It doesn't smell at all. What can it be? Is it AC coolant or just water the AC generates when its running?
Thanks a million for your help!
Lars |
04-07-08, 09:59 PM
|  | Cadillac Owners Member Cadillac(s): 2001 Cadillac DTS, 2006 Cadillac SRX | | Join Date: Dec 2006 Location: New Jersey Age: 37 | | | Re: Eldorado 1999 Water passenger side carpet Sounds like you evaporator drain is plugged. You'll have to go underneath and either blow it out with compressed air or try to get something thin in the drain to clean it out. |
04-07-08, 10:04 PM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: Eldorado 1999 Water passenger side carpet evap core is mounted on the engine side of the firewall
the heater core is the one mounted inside the car
im betting heater core
does it smell like dex? |
04-07-08, 10:19 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 90 Eldo -SOLD-, 98 ETC -SOLD-, 86 XR4Ti Track Car, 07 Ranger | | Join Date: May 2004 Location: Atlanta, GA Age: 27 | | | Re: Eldorado 1999 Water passenger side carpet 99.99% it's the heater core, up under the dash behind a plastic cover, makes the carpet wet... |
04-07-08, 10:37 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Eldorado 1999 Water passenger side carpet Is the heater core connected to the main engine cooling system? It really smells like nothing and the water is clear, like from the faucet. can i repair/fix it myself? I used to be a car mechanic back in the 1980's. Or is it AC related? The water is freezing cold. Obviosly I will start with easy fixes, like trying to unplug the evaporator drain. Thank you! |
04-08-08, 10:44 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 90 Eldo -SOLD-, 98 ETC -SOLD-, 86 XR4Ti Track Car, 07 Ranger | | Join Date: May 2004 Location: Atlanta, GA Age: 27 | | | Re: Eldorado 1999 Water passenger side carpet heater core is connected to coolant system yes. It may be A/C related, could have condensation from the A/C system not properly draining though I've never heard of this... |
04-08-08, 11:07 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: Eldorado 1999 Water passenger side carpet Lars,.......There's a condensate drain fitting for the evaporator on the lower right side of the A/C blower box in front of the console trim panel. You might be able to see it from the left foot passenger carpet panel area...the panel will pull off. The hose goes down under the car on the passenger side or into the right lower fenderwell area. Find the hose outlet and blow it clear. Dust, dirt, leaves. Service manual shows a 90 degree drain fitting....... | | Cadillac Discussion Tools | | |
Censor is ON | | | |
