| Cadillac Seville / Cadillac Eldorado Forum Forum for discussions regarding the past Seville and Eldorado. | Cadillac Forums: A/C, Driver side warm, Pass side cold.
03-28-08, 08:58 PM
| | Cadillac Owners Member Cadillac(s): 1999 Seville SLS | | | | | A/C, Driver side warm, Pass side cold. 1999 cadillac seville is blowing cold air on passenger side, but not on the driver side. Can anyone tell me what is wrong? |
03-28-08, 09:07 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: A/C, Driver side warm, Pass side cold. Common symptom of low refrigerant on a dual zone system, but not quite low enough to set a DTC or disable the compressor. Have it serviced. Just needs a top off. |
06-05-08, 01:36 PM
| | Cadillac Owners Member Cadillac(s): 1999 Seville SLS | | | | | Re: A/C, Driver side warm, Pass side cold. Thanks for the info., I just got around to it a couple weeks ago. I had my uncle top it off, and now it works beautifully, it's cold. I think he said he added 3lbs. to the system, once he did it, the driver side kicked in with some cold air. |
06-05-08, 01:43 PM
| | Cadillac Owners Member Cadillac(s): 1999 Seville STS | | Join Date: Dec 2006 Location: Finland | | | Re: A/C, Driver side warm, Pass side cold. I had the exact same issue (-99 Seville STS), but for me the solution was a faulty driver side air mix door actuator. The strange thing was that there were no codes, altough a failed actuator is supposed to set one. |
06-05-08, 05:54 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: A/C, Driver side warm, Pass side cold. Quote:
Originally Posted by chitosls Thanks for the info., I just got around to it a couple weeks ago. I had my uncle top it off, and now it works beautifully, it's cold. I think he said he added 3lbs. to the system, once he did it, the driver side kicked in with some cold air. | ADDED 3 lbs!? YIKES. I seem to recall the system only holds 2. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
