Cadillac Forums: 1993 sts won't fire below 32 degees
  #16 (permalink)
Old 03-05-08, 12:58 AM
Logandiagnostic's Avatar
Cadillac Owners Enthusiast
View Logandiagnostic's Photo Album
Casino Cash: $2755
Re: 1993 sts won't fire below 32 degees
When you say wont start, do you mean 'no crank' or 'it cranks but wont fire'?
If it is a 'no crank'. Check the 'starter enable relay'. It is under the carpet, under the lower floor trim about 1/2 way between the lower driver door opening. These can get wet and green.
If it cranks, but no start. Do you hear the fuel pump run for about 2 seconds as the key is first turned to 'on'? If no, it can be blued/burnt wire connections at the fuel tank.
Many of the relays underhood can also go green. Inspect them also.
I attached a pic of a blued fuel pump connector. In this case it is not a GM plug. And most of the time they do not look as bad as this one. You have to look really close..
Logan Diagnostic LLC
www.ledfix.com
www.airbagcrash.com
www.logandieselusa.com
  #17 (permalink)
Old 03-05-08, 03:26 AM
Cadillac(s): 88 CPE DV, 93 ELDO TOURING
View raymondk's Photo Album
Casino Cash: $1025
Try heating the ignition control module (its the flat square base under the coils) with a hair dryer for a few minutes when you know its too cold to start. My 93 ELDO N* wouldn't start if it had run over 5 minutes, but wouldn't quit. After turning it off, it wouldn't restart for hours. Melting an ice cube on the base of the ICM made it start instantly. I realize yours is the opposite but the same temperature effect could cause it to not start. The fault tree said PCM but the ice said ICM and that was it.
Tags: , , , , ,
1993, degees, fire, sts
