Cadillac Forums: A little bit of insight for a fellow STS enthusiast.
Old 02-28-08, 09:26 AM
99STSeville's Avatar
99STSeville 99STSeville is offline
View 99STSeville's Photo Album
Casino Cash: $295
Cool A little bit of insight for a fellow STS enthusiast.
So I've had my Cadillac for a while now, and gone through all the motions. Replaced every window motor regulator in the car, after seeing them all fail one by one. No biggy, found a set of 4 out of the same model that had gotten blasted in the front. Got'em cheap. Service theft system started showing, now I've heard a couple different theories on this, one being as easy as a lose wire.... input would be appreciated on this 1. Had the front left tweeter blow, replaced with Infinity Kappa 10.7 and am happier now than i was the the factory sound. Now I'm starting to run into a couple of other problems. My motor mounts are going, if not already gone. I'd really like to know where I can get a set of the re-designed ones with the heat shield for under $225 like the dealer wants. Also, passenger side drive axle (outer) boot has become loose and now spins, can I get this packed and re-sealed?? cheapest replacement (re-man'd OK)? Avg Labor cost to change out individual axle? Also brakes shudder a bit when braking, easiest way to fix this? just got rid of the dreaded 65-75 shimmy with a new set of Vogue tyres all road-forced balanced and began to notice these other problems. Thanks guys! She will thank you too!!!
<a href="http://s85.photobucket.com/albums/k7...=thewhippp.jpg" target="_blank"><img src="http://i85.photobucket.com/albums/k7.../thewhippp.jpg" border="0" alt="Photobucket"></a>
  #2 (permalink)
Old 02-28-08, 05:34 PM
chubbyranger chubbyranger is offline
Not to be confused with the real Ranger
Cadillac(s): 99 Z-rated STS, 90 Coupe Deville (sold)
View chubbyranger's Photo Album
Casino Cash: $9655
Re: A little bit of insight for a fellow STS enthusiast.
Theft system: pull codes (Info ^ + ON/OFF)
http://www.cadillacforums.com/forums...s-warning.html (How to pull Codes and got codes or warning lights? Look here!)
That will tell you where to start with that message.
Motor mounts, try:
www.gmpartsdirect.com
www.gmotors.com
www.rockauto.com
Drive axle: NFI
Brake shudder sounds like warped rotors. Get them turned or replaced, I would lean toward replacement (and don't really know if they can be turned on these cars).
Call a dealer with the VIN and see if the alternator recall has been done. 99% likely it has, but ask anyway.
Tags: , , , , ,
bit, enthusiast, fellow, insight, sts
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
earn
vacation travel
golf store
silver, gold, diamonds
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods
