Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Thread: Suddenly Won't start, no Spark, 1985 Eldorado
  1. #16
    Logandiagnostic's Avatar
    Logandiagnostic is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 DTS, 2005 Mustang GT, 2010 MINI S
    Feb 2003
    Franklin, TN
    1,118
    Re: Suddenly Won't start, no Spark, 1985 Eldorado
    No pulse from the ignintion system = no injector pulse from the ECM.
    I suspect a bad IC module. Common GM problem of that era..
    Logan Diagnostic LLC
    www.ledfix.com
    www.airbagcrash.com
    www.logandieselusa.com
  2. #17
    jhcatlin is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Feb 2008
    7
    ok - taking car back to my house via tow truck. Gonna replace IC module and pickup coil, hopefully that will fix her - I'll keep y'all posted for future readers
  3. #18
    busayman is offline Cadillac Owners Member
    Automobile(s): 1984 Coupe DeVille HT4100
    Jun 2013
    Houston Tx.
    52
    16
    Just bought a 1984 Coupe deville ht4100. She turns over but I get no gas. she was parked for over a year with 1/2 tank fuel. I dropped some sea foam in the tank, sprayed some starting fluid in the carb. she starts with the starting fluid but then stalls when I stop spraying... when I have my son push the accel pedal with ignition on no gas comes up into the carb. changed the fuel filter, checked the fuses and now I am stumped. Just bought a fuel pump but don't want to put it in if it's going to be a waste of time (i.e not the problem). Please advise.
  4. #19
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,688
    You posted onto a 5 year old thread??? You have no carb. You have a throttle body. While this car cranks over, there should be 2 distinct sprays of fuel coming from the injectors within the throttle body. Touching, pressing on the "accel pedal" has no effect. Its an air pedal! the driver presses on the pedal to admit more air to the engine, the computer then matches that air with the proper amount of fuel. Have someone listen at the fuel filler neck for a buzzing fuel pump when you turn the key to the RUN position. It should buzz for like 10 seconds then quit. The fuel pump is wired thru the oil pressure sender above the oil filter. If that harness is disconnected or damaged, no voltage will go to the pump in the tank. Did you test the fuses with the key on and use a voltmeter or a test light?
  5. #20
    ChrisPFlorida is offline Cadillac Owners Member
    Automobile(s): 1985 Cadillac Seville
    Nov 2015
    Fort Lauderdale, Florida
    5
    For people looking for answers to this problem (as I have)
    85 Seville 4100
    Running fine except idle was rough/pulsing. Replaced ICM motor and went through adjustment cited in manual. While adjusting, engine stalled, and that was it - would not start again.
    Ran diagnostics and got a hard code 12, which is no tach from distributor. Without further checks, I assumed it was the control module in the distributor, so I replaced it. No start. Tried replacing the coil just for fun..no start.
    At this point I am still getting the 12 code, and no spark at the plugs. I'm going through the tests suggested in the manual now; at this point I think it may be the pickup coil. I will post more on this when I have more answers.
    YAY 80s electronics!
    -CP
  • You may not post replies
