94 Eldorado - Code P094 - Please help / Any ideas?
Results 1 to 15 of 15
Cadillac Seville / Cadillac Eldorado Forum Discussion, 94 Eldorado - Code P094 - Please help / Any ideas? in Past Cadillac Vehicle Discussion; I have a 1994 Cadillac Eldorado with 76k miles. 1st, 2nd and 3rd gears work great, but when it is ...
    1focus4real is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Feb 2007
    87
    1st, 2nd and 3rd gears work great, but when it is time to shift into overdrive (45 mph)the Check Engine light pops on and the car goes into limp mode. Feels almost as if the tranny goes out or low tranny fluid, the RPMs are higher just to keep up at around 45-50 Mph. When I stop and wait a few minutes, turn the car back on, the Check Engine light is off and the car runs fine... until I hit around 45Mph again when the same thing happens.
    I've cleared all codes and the only one that is current is P094 when the Check Light comes on.
    Any ideas?
    Thanks in advance.
    chubbyranger is offline Cadillac Owners Connoisseur
    Automobile(s): 99 Seville STS, 08 STS4 N* 1SG F55
    Apr 2007
    The Ocean State
    53
    3,516
    Re: 94 Eldorado - Code P094 - Please help / Any ideas?
    http://myweb.accessus.net/~090/dtcobd1.html
    P094 (E094) ............ Transaxle Shift "A" Solenoid Problem (Vehicle Speed Sensor)
    Not sure what to do about it, but there's the translation.
    Feb 2007
    87
    Right on thanks, I just looked that up too and was just about to reply to my own post with a little more info.
    Tranny fluid is good, I'm going to check all the fuses next.
    -If I were to replace the VSS (Vehicle Speed Sensor), would that take care of the problem?
    Meaning is the Shift "A" Solenoid within the VSS?
    kdcing is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Eldorado, 4.9L, 200k miles
    Dec 2006
    273
    2 separate pieces....Shift "A" Solenoid within the tranny case...VSS elsewhere (not certain exactly where it is, but it may be located on 1 of the output shafts of the transmission).
    Specific troubleshooting steps around page 228-230 @ the following:
    http://www.v8mr2.com/reference/Tests_with_codes.pdf
    Feb 2007
    87
    I think the VSS is on the side, but outside of the tranny...
    So the P094 code could be triggered by one and/or two possible malfunctions?
    69
    82,177
    The VSS is mounted on top of the right output shaft housing. It is visible through the right wheel well with the car jacked up and the wheel hanging.
    firstimecaddi is offline Awaiting Email Confirmation
    Automobile(s): 94 Seville; 95 FWB
    Apr 2006
    Out of my mind
    653
    PO94 is the shift solenoids related. They (2 of em) have to be removed and replaced. But there are not too hard to get at. The solenoids break over time b/c of something about the filter hitting against the solenoids. There is a replacement kit available that includes a bracket, and a screw, that prevents further failure. If you are a DIYer it's not too bad a job.
    ....you might luck out and find a How-To if you do a search.
    Feb 2007
    87
    Right on, thanks a lot to both of you.
    So the question is now: which one to replace first? The shift solenoid or the VSS?
    The VSS is cheaper and easier to get to, so should I replace that first?
    or does this problem sound more like the shift solenoid after all?
    69
    82,177
    Not sure. Maybe someone else will know.
    Apr 2006
    Out of my mind
    653
    When I got the PO94 the only thing I changed was the solenoids and that was all. I see you mentioned someting about VCC/VSS I don't know anything about that. The shift solenoids aren't all that expensive, about $60 for the kit. To get to em, you'd have to remove the pan, oil transfer plates and the lower valve body. This would also be a good time to change your transmission fluid.
    Feb 2007
    87
    Ok I ordered the Solenoid kit. Gonna replace that first and keep the post updated with any developments in case others search for this in the future.
    The reason I mentioned the VSS is because when I looked up what P094 meant it said : " Transaxle Shift A Solenoid Problem (Vehicle Speed Sensor) "
    So I figured it might've been the VSS.
    Either way will keep you posted, otherwise feel free to chime in with any other advice. Thanks a million so far.
    Dec 2006
    273
    I think that you are doing the right thing by changing the shift solenoids. From the problem statement, @ around 45mph weird stuff happens (i.e. the Check Engine light pops on and the car goes into limp mode. Feels almost as if the tranny goes out or low tranny fluid, the RPMs are higher just to keep up at around 45-50 Mph.). It sounds like the transmission simply does not get into 4th gear. Additionally, I checked another code list and P094 = Transaxle Shift Solenoid "A" Problem....it does not mention the VSS issue. (I have, however, seen the list that you referred to, which indicates both the Shift Solenoid & VSS.....which description is more correct??....[shrug shoulders])
    In any case, a few other troubleshooting tips:
    1. When in PCM Diagnostics, monitor the "Degrees F" icon on the HVAC readout. At around 42-45mph, the PCM should command the trans to shift into 4th gear. The "Degrees F" should illuminate to show that the trans got into 4th. On your car, "Degrees C" will likely stay illuminated indicating that it is still in 3rd.
    2. Does the speed indicated on the Speedo seem correct? If yes, then the VSS is likely ok as I believe the Speedo is fed data from the VSS. As a double-check, see if the speed indicated in Diagnostics (i.e. PCM Data? => PD12) is about the same as the speed indicated on the speed.....if they match - and if the indicated speeds seem correct to the car's actual speed - then the VSS is likely ok.
    3. The shift solenoids can be excercised manually via the PCM Outputs in the Diagnostics (PO10 = Shift Solenoid A, PO11 = Shift Solenoid B). The PCM Output function is supposed to trigger the solenoids "On" and "Off" every 4 seconds. I haven't used the function myself, but I believe if you hear a click from inside the trans every 4 seconds, then the solenoid is firing correctly. Your B solenoid appears to be working, so test B 1st to determine what a "good" solenoid sounds like.
    Finally, if/when you change the solenoids, be sure to install the "L" bracket that comes w/ the kit. In the last 6-9 months, somebody had a writeup about NOT installing the "L" bracket and some problem happened upon startup after the solenoid replacement (...if memory serves me correctly, I recall that there was a clunk at startup and then the trans would not shift correctly because the solenoids popped out of place.)
    Dec 2006
    273
    Btw...the information above ^^^^ is from a troubleshooting guide for a '95 Northstar....it should apply to your engine, but there may be some differences.
  16. #14
    frederii is offline Cadillac Owners Member
    Automobile(s): 94 eldoado
    Jun 2009
    1
    Make sure you use the bracket. I did mine yesterday and still get a P029 code.
    I did not know where it went, or if it was needed.
    Do I need to put it in? I went 190,000 without it. I am wondering if it could be the PCM,
    or wire harness?
  17. #15
    Heart-of-Ohio is offline Cadillac Owners Member
    Automobile(s): 95 ETC. 66 Impala 427 Sport Coupe
    Apr 2009
    23
    I had this problem in April when I bought my 95 eldo. It would not shift from 3rd to 4th. Then a few weeks later the tranny would not shift from 2nd to 3rd.
    I purchased the solenoid kit.
    I completed the solenoids A & B project a few weeks ago. I was getting a P094 code along with others. The new solenoids fixed the problem.
    I took 2 days to install the solenoids. The first day I removed the tranny pan and let it drain over night. The next day I remove the valve body, removed the solenoids and installed the new ones. I used the instructions I found here to complete the job. (This job could only take a few hours, 2 to 4.)
    To me it sounds like the solenoid kit would fix your problem.
    Good Luck
    I just realized that this is an old post. LOL
  18. Remove Advertisements
