| Cadillac Seville / Cadillac Eldorado Forum Forum for discussions regarding the past Seville and Eldorado. | Cadillac Forums: 1995 STS serpentine belt replacement-easiest way???
02-09-08, 10:15 AM
| | Cadillac Owners Member | | Join Date: Sep 2005 Location: Ohio | | 1995 STS serpentine belt replacement-easiest way??? I just had an idler pully dismount from the bearing and now I have to re-install a new serpentine belt. There is not much room and I am having difficulties weaving thru the many pullys. Any help on the best way to route the belt???
Jeff |
02-09-08, 10:21 AM
| | N* Headgasket Survivor Cadillac(s): 99 Z-rated STS, 90 Coupe Deville (sold) | | Join Date: Apr 2007 Location: The Ocean State Age: 46 | | | Re: 1995 STS serpentine belt replacement-easiest way??? The belt routing is usually under the hood on a sticker on the radiator cowl. Put a 1/2" breaker bar or ratchet into the tensioner and pull it back. Weave the belt carefully through, I usually start on the crankshaft pulley and work my way up and out. Its way easier if you have a 2nd person to crank the tensioner back while you seat the belt because there is not much slack to work with and holding the tensioner and getting the belt on by yourself can be a real beach. |
02-09-08, 12:31 PM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: 1995 STS serpentine belt replacement-easiest way??? just dig in and go to town
no real better way of doing it other than start at the bottom and work your way up
and oh yea dont forget the routing lol |
02-09-08, 04:49 PM
| | Cadillac Owners Member | | Join Date: Sep 2005 Location: Ohio | | | Re: 1995 STS serpentine belt replacement-easiest way??? I did see the routing diagram on the cowl. I took your advise and worked my way up. Not too difficult. I was even able to pull the tension pulley and wrap the belt around the power steering pump last. Thanks! |
02-12-08, 12:53 AM
|  | Cadillac Owners Fanatic Cadillac(s): Eldo | | Join Date: Jan 2004 Location: NJ now in FLA | | | Re: 1995 STS serpentine belt replacement-easiest way??? this is good information.. i'm due for a belt good deal.. thanks for posting  |
04-21-08, 06:12 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: 1995 STS serpentine belt replacement-easiest way??? i need a diagram for routing of serpentine belt on a 1995 Cadillac Eldorado ETC, can someone help me out pleeeeeeze. It is not on the car anywhere darn it. |
04-21-08, 06:25 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 94 Eldorado, and a totaled z rated STS | | Join Date: Sep 2004 Location: Hilo, Hawaii Age: 22 | | | Re: 1995 STS serpentine belt replacement-easiest way??? Quote:
Originally Posted by tammykimtony i need a diagram for routing of serpentine belt on a 1995 Cadillac Eldorado ETC, can someone help me out pleeeeeeze. It is not on the car anywhere darn it. | Here ya go,  |
06-06-08, 09:16 PM
|  | Cadillac Owners Fanatic Cadillac(s): 1996 SLS, 1985 Seville Commemorative Edition, 1969 Sed. Dev. | | Join Date: Feb 2004 Location: East Lansing, MI Age: 24 | | | Re: 1995 STS serpentine belt replacement-easiest way??? Get a length of copper pipe, bend a 90 and flatten about an inch or two in it at one end. Use the flattened end to manipulate the belt into place. This tip was posted on another thread about routing the belt through those hard to reach places. I'll be replacing the S belt on my 96 SLS very soon... I looked at it today and it's nearly split into two separate bands... ouch. |
06-07-08, 12:56 AM
|  | Cadillac Owners Enthusiast Cadillac(s): 90 Eldo -SOLD-, 98 ETC -SOLD-, 86 XR4Ti Track Car, 07 Ranger | | Join Date: May 2004 Location: Atlanta, GA Age: 27 | | | Re: 1995 STS serpentine belt replacement-easiest way??? "easiest" way involves jacking your pass front tire, remove it, remove inner splash guards, gives easy access to the crankshaft, A/C compressor, and idler pulleys, becomes a simple 1 man job and is very painless... |
06-14-08, 12:38 AM
|  | Cadillac Owners Member Cadillac(s): 93 Cadillac Eldorado SC | | Join Date: Jun 2008 Location: Dallas,Tx | | | Re: 1995 STS serpentine belt replacement-easiest way??? Quote:
Originally Posted by Raze "easiest" way involves jacking your pass front tire, remove it, remove inner splash guards, gives easy access to the crankshaft, A/C compressor, and idler pulleys, becomes a simple 1 man job and is very painless... | I thinks this is a easiest way. |
08-25-08, 02:35 AM
|  | Cadillac Owners Member Cadillac(s): 1995 Eldorado | | Join Date: Aug 2007 Location: Tucson, AZ Age: 30 | | | Re: 1995 STS serpentine belt replacement-easiest way??? There is def. a lot of good advice posted here for serpentine belt R&R. Replaced mine tonight after reading this thread. took about 40mins. I started with the 2 large pulleys at the bottom and then got it routed only by-passing the tensioner pulley. However, gravity kept pulling the belt off the lower pulley closest to the windshield (largest pulley). Tried using a prod, poking from the top to finesse the belt onto the lower large pulley, no dice. It pays to have long skinny arms here
Next I had my roommate pull the breaker bar on the tensioner while I laid under the car, pulled away some plastic, and then fitted the belt around the big pulley. He let go of the tensioner and the rest fell in line. The belt I had was cracked, but most of all it was noisy. I had spilled coolant all over it checking for a popped HG in July. ...It'd be great if someone can label the rest of the diagram and repost it
1995 Eldorado ESC
Reason: posted pics in wrong format
08-25-08, 03:11 AM
|  | Cadillac Owners Member Cadillac(s): 1995 Eldorado | | Join Date: Aug 2007 Location: Tucson, AZ Age: 30 | | | Re: 1995 STS serpentine belt replacement-easiest way??? Pardon me. I just saw the labeled diagram on page 1 of this thread. Well done!
Reason: misspell
08-27-08, 05:45 AM
|  | Cadillac Owners Member Cadillac(s): 1995 Eldorado | | Join Date: Aug 2007 Location: Tucson, AZ Age: 30 | | | Re: 1995 STS serpentine belt replacement-easiest way??? | | Cadillac Discussion Tools | | |
Censor is ON | | | |
