| Cadillac Seville / Cadillac Eldorado Forum Forum for discussions regarding the past Seville and Eldorado. | Cadillac Forums: Got oil analysis done..who can read it
01-12-08, 01:48 PM
|  | Cadillac Owners Fanatic Cadillac(s): Eldo | | Join Date: Jan 2004 Location: NJ now in FLA | | | Got oil analysis done..who can read it Ok, so i sent my oil kit for oil analysis.. any chem folks here that can read the data.. it looks ok to me from the directions on the back but just wanted to get some feedback on the results.. i have to load the pic.. scanner broke.. have to snap a pic..thanks |
01-12-08, 02:03 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: Got oil analysis done..who can read it The analysis probably has iron, aluminum, lead, antifreeze, water, some acids, and maybe phosphorous or a couple more contaminants as well as a general viscosity readout.
By itself it doesn't mean much....it's the trends over time that count. I would hope that your analysis lab has included a "how to" sheet, giving you some guidelines.
Obviously, high levels of iron (oil pump, timing gear/chains, rings and cylinder liners), lead/antimony (various bearing metals), aluminum (pistons), plastics (chain slippers), and any antifreeze are not good.
I haven't tried it, but Google "oil analysis" and groom the search for car engines. |
01-13-08, 12:17 AM
|  | Cadillac Owners Fanatic Cadillac(s): Eldo | | Join Date: Jan 2004 Location: NJ now in FLA | | | Re: Got oil analysis done..who can read it Thank you for the reply.
I did get sample date info, plus spectrochemical analysis (ppm) and physical properties readings..
The results of the tests performed indicate no corrective action required *****
that is what it stated but i wanted to share the numbers with others to see what they really mean, as far as wear for the components with a motor at this mileage, etc..
I will try the google search and have to get the paper scanned in.. the pics came out pretty bad.. could not even read the small print.. |
01-13-08, 12:38 AM
| | Cadillac Owners Connoisseur Cadillac(s): 1997 Eldorado | | Join Date: Apr 2005 Location: Oakland County, MI Age: 26 | | | Re: Got oil analysis done..who can read it While oil analyses can provide valuable instant information, their real usefulness is in exposing trends and patterns. For example, if you show higher and higher levels of copper, zinc, and lead, it would show that your bearings are being worn at higher and higher rates. This could be indicative of a worsening bottom end lubrication issue.
In other words, it's more often that the importance of the information contained within a single oil analysis pales in comparison to the collective interpretation of successive oil analyses.
Now, as was pointed out before, things like suspended plastic particles, coolant, excessive light hydrocarbons, and more than small quantities of water are almost always immediately bad, and diagnostic action should be taken immediately. |
01-13-08, 12:50 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 1998 SLS - 160,000 mi | | Join Date: Dec 2004 Location: Petoskey, MI Age: 28 | | | Re: Got oil analysis done..who can read it and how much does such a test cost? I think I will choose to remain ignorant.  |
01-13-08, 03:58 AM
| | Cadillac Owners Connoisseur Cadillac(s): 1997 Eldorado | | Join Date: Apr 2005 Location: Oakland County, MI Age: 26 | | | Re: Got oil analysis done..who can read it Ignorant? How dull...
No, serioiusly, it's about $50 to have it done. Sometimes I've seen it for as little as $20 or 25. |
01-13-08, 01:29 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Got oil analysis done..who can read it In the FWIW category, I think there is WAAAAY too much obsession about oil. Just my $0.02. |
01-13-08, 10:20 PM
|  | Cadillac Owners Fanatic Cadillac(s): Eldo | | Join Date: Jan 2004 Location: NJ now in FLA | | | Re: Got oil analysis done..who can read it I bought the kit for like 25-30 bucks... not an obsession, just want to keep my ride for a while.. i love the car.. and i really want to have the oil analyzed every so often to see if anything abnormal is going on.. i know all of us have a bit of an anal or should i say detailed oriented nature that is why most of us like to do our own work on ours cars..
At least with this analysis i will have a point of reference for the future.
Thank you for the input.. |
01-13-08, 10:25 PM
| | N* Headgasket Survivor Cadillac(s): 99 Z-rated STS, 90 Coupe Deville (sold) | | Join Date: Apr 2007 Location: The Ocean State Age: 46 | | | Re: Got oil analysis done..who can read it Quote:
Originally Posted by Ranger In the FWIW category, I think there is WAAAAY too much obsession about oil. Just my $0.02. | While I am another of the "no such thing as too much data" geeks, when was the last time someone had a N* oil related failure? |
01-13-08, 10:36 PM
|  | Cadillac Owners Fanatic Cadillac(s): Eldo | | Join Date: Jan 2004 Location: NJ now in FLA | | | Re: Got oil analysis done..who can read it I don't want to open up the oil war theme but i just want to keep an eye on things.. the integrity of the oil was fine and i think i will stick with the mileage interval that i have and the oil type, it works for me. But better to have the information and not need it, than need it and not have it  |
01-14-08, 12:44 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 2003 White Diamond DHS | | Join Date: Jan 2005 Location: Dallas, TX | | | Re: Got oil analysis done..who can read it I am interested in the anti-wear additive presence, namely ZDDP or ZDP. (zinc).
How much Oil Life was left on that oil you sent? Ideally you sent it in with like 7500 miles or more if your car is newer (2000+) (oil life monitor maximum). Let me know, what year your car is, and how much oil life was left as per the OLM when u sent it in, and how much Zinc was in the oil. |
01-14-08, 10:34 AM
|  | Cadillac Owners Fanatic Cadillac(s): Eldo | | Join Date: Jan 2004 Location: NJ now in FLA | | | Re: Got oil analysis done..who can read it Well, car in question 96 eldo with 77k miles.. miles on oil 4121 life was around 15%...(don't remember i think i wrote it down somewhere) zinc reading 779 PPM |
01-14-08, 11:16 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 2003 White Diamond DHS | | Join Date: Jan 2005 Location: Dallas, TX | | | Re: Got oil analysis done..who can read it what brand/weight of oil? (dino or synth, etc) I'm going to try to look up the zinc content of the oil. |
01-15-08, 12:38 AM
|  | Cadillac Owners Fanatic Cadillac(s): Eldo | | Join Date: Jan 2004 Location: NJ now in FLA | | | Re: Got oil analysis done..who can read it I use mobil1 full synthetic 10w 30. Thank you.  | | Cadillac Discussion Tools | | |
Censor is ON | | | |
