Cadillac Forums: 94 sts starting problem *plz help*
Old 01-04-08, 09:42 PM
Cadillac(s): Cadillac
View sweetshot's Photo Album
Casino Cash: $1415
So heres the story ive got a 94 sts with the northstar engine which ive owned for just over a year. The car has never not started or not turned over for the entire time ive owned the car till now. I recently took the car off the road for about 3 months and have been driving it for about 2-3 weeks now. When i first tried driving the car after 3 months the battery was dead. I charged it and seemed fine for a few days. A couple days later i went to start the car and nothing happened, all acc came on but nothing from the starter or crank, i then turned the key back then tried starting it again and it fired right up. I took the batt in and turns out it was bad so i got it replaced. When i replaced the batt i cleaned the conn cables which had corrosion on it and it fired up just fine..so i thought the problem was solved then a few days later it did the same thing again, turned the key to start it, nothing, turned it back and tried again, fired up just fine. this is happening at completely random times when the car is hot or cold doesnt matter. Recently when ive started it the starter goes and the crank goes but then just stops dead after about a second of turning over. I turn the key back and try again and it starts just fine. Theres no grinding or any bad noises coming from the engine or starter. Any input would be greatly appreciated before i go out and put a new starter in. Thanks
  #2 (permalink)
Old 01-04-08, 10:16 PM
View Ranger's Photo Album
Casino Cash: $24241
Re: 94 sts starting problem *plz help*
Kind of sounds like a bad ignition switch to me.
  #3 (permalink)
Old 01-05-08, 02:56 AM
Krashed989's Avatar
Cadillac(s): 94 Eldorado, and a totaled z rated STS
View Krashed989's Photo Album
Casino Cash: $10958
I agree with Ranger. Try spraying some WD-40 in the ignition to see if that helps, but know it is only a band-aid if it does help.
  #4 (permalink)
Old 01-05-08, 06:54 AM
Casino Cash: $1415
What does wd-40 do to the switch? Any chance its one of the cables off the batt? Or connection to the starter. Thanks
  #5 (permalink)
Old 01-05-08, 10:05 AM
N* Headgasket Survivor
Cadillac(s): 99 Z-rated STS, 90 Coupe Deville (sold)
View chubbyranger's Photo Album
Casino Cash: $2200
Here's another possibility - the starter enable relay could be going bad. Assuming 94 is VATS (resistor chip in the key) and the design didn't get more complicated from 1990, the start signal from the ignition goes to the starter enable relay, from there to the neutral safety switch (NSS) and from there to the starter solenoid. If your starter enable relay is going south it could exhibit the symptoms you describe. Of course its usually buried under the dash all by itself so enterprising theives can't just open up the relay center and jump it. It could also be the NSS - try starting it in neutral for a couple of days and see if that changes anything.
  #6 (permalink)
Old 01-05-08, 10:09 AM
View gomarkiiv's Photo Album
Casino Cash: $815
Check to see if the insert on the key is loose. Use another key if you have one.
Tags: , , , ,
plz, problem, starting, sts
