Cadillac Forums: IS this a botched connector or what, near the trans, looks like a PCM connector
Old 12-26-07, 08:55 AM
Cadillac(s): 98 sls
View Crown Vic Owner's Photo Album
Casino Cash: $5564
Almost, i dont know for sure, i think this is odd, it looks almost like one of those make a connector connectors. Its on the right side of the coolant tank in that area.
  #2 (permalink)
Old 12-26-07, 09:54 AM
CadillacSTS2003's Avatar
Zeeee-yaaaa
Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC
View CadillacSTS2003's Photo Album
Casino Cash: $12230
Re: IS this a botched connector or what, near the trans, looks like a PCM connector
rofl
not a pcm connector
it is however a max connector
why do you ask?
  #3 (permalink)
Old 12-26-07, 12:44 PM
Cadillac(s): 98 sls
Casino Cash: $5564
dont laugh, i honestly dont know what its for.
I got curious after all the BS with this car.
Its just that the connector looks homemade for some reason.
  #4 (permalink)
Old 12-26-07, 02:00 PM
N* Headgasket Survivor
Cadillac(s): 99 Z-rated STS, 90 Coupe Deville (sold)
View chubbyranger's Photo Album
Casino Cash: $2200
I will look at my 99 if I can get it back from the wife after I finish changing the alternator in her Concorde. PITA I would bet that is factory but somebody gooned up the backshell/cover.
  #5 (permalink)
Old 12-26-07, 07:17 PM
Casino Cash: $2200
I have the same hacked up looking POS on my fenderwell. Double sided with wires hanging out. No idea what it does but I hope its not important.
  #6 (permalink)
Old 12-26-07, 08:18 PM
View weephee's Photo Album
Casino Cash: $2490
If I'm looking at the photo correctly I would say it's the main connector between the body harness which goes through the firewall and the engine harness. There should be a bracket attached to the drivers side strut tower to support it. If that's it, it is very important.
  #7 (permalink)
Old 12-26-07, 10:57 PM
Cadillac Owners Enthusiast
Cadillac(s): 99STS,98 Deville Scrapped.1997 GrandPrix GTP
View Caddyshack100's Photo Album
Casino Cash: $6439
Weephee is right, its very important, heres what it contains; C101
Connector Part Information
15304900
40 Way F 150/280 Series(BLK)
Body Harness Connector
15317380
40 Way M 150/280 Series (BLK)
Engine Harness Connector
Pin
Wire Color
Circuit No.
Function
Pin
Wire Color
Circuit No.
Function
A1
LT BLU/BLK
396
Cruise Control Signal - Engaged
A1
LT BLU/BLK
396
Cruise Control Signal Engaged
A2
DK GRN
83
Cruise Control Inhibit Output
A2
DK GRN
83
A3
WHT
1765
Steering Wheel Position Signal - Marker Pulse
A3
WHT
1765
A4
YEL
5
Ignition Positive Voltage
A4
YEL
5
A5
GRY
120
Fuel Pump Motor Feed
A5
GRY
120
A6
BLK
904
Not Used - From Generator
A6
BLK
901
A7
DK GRN/WHT
465
Fuel Pump Relay Feed
A7
DK GRN/WHT
465
Fuel Pump relay Feed
A8
ORN
1610
Brake Lining Wear Indicator Signal-Left Rear
A8
ORN
1610
B1
PPL
1807
Class 2 Serial Data Line
B1
PPL
1807
B2
DK BLU
716
Yaw Rate Sensor Signal
B2
DK BLU
716
B3
LT BLU
715
Lateral Accelerometer Signal
B3
LT BLU
715
B4
GRY
1337
Yaw Sensor Feed
B4
GRY/BLK
1337
Yaw Sensor Feed
B5
LT GRN/BLK
1338
Yaw Sensor Signal - Ground
B5
LT GRN/BLK
1338
B6
LT GRN
1763
Steering Wheel Position Signal - Encoder Channel A
B6
LT GRN
1763
B7
LT BLU
1764
Steering Wheel position Signal - Encoder Channel B
B7
BLU
1764
B8
WHT
121
Tachometer Signal
B8
WHT/BLK
121
Tachometer Signal
B9
GRY
847
ABS Switch Input
B9
GRY
847
ABS Switch Input
B10
LT BLU
725
Voltage Regulator Output - Temperature Compensated Voltage
B10
LT BLU
725
B11
PPL
1490
Computer Command Ride Module Signal - Wide Open Throttle
B11
PPL
1490
B12
WHT
17
Stoplamp Switch Output
B12
WHT
17
C1
PPL
420
Brake Pedal Switch Output - Torque Converter Clutch
C1
PPL/WHT
420
C2
BRN/WHT
419
Check Engine Indicator Lamp Input
C2
BRN/WHT
419
C3
GRY
605
5 Volt Reference
C3
GRY
605
5 Volt Reference
C4
DK GRN
890
Fuel Tank Pressure Sensor Signal
C4
DK GRN
890
C5
BLK
808
Sensor Ground
C5
BLK
808
Sensor Ground
C6
DK BLU
1537
ABS Indicator Lamp Output
C6
DK BLU
1537
C7
WHT
790
ICCS Data Link - LH
C7
WHT
790
ICCS Data Link - LH
C8
GRY
791
ICCS Data Link - RH
C8
GRY
791
ICCS Data Link - RH
C9
LT BLU
1059
Steering Wheel Position Sensor Signal
C9
LT BLU
1059
C10
PPL
1807
C10
PPL
1807
C11
WHT
1310
EVAP Purge Control Output
C11
WHT/BLK
1310
C12
DK GRN/WHT
817
Vehicle Speed Sensor - 4000 Pulses Per Mile
C12
DK GRN/WHT
817
D1
BRN
882
RH Rear Wheel Speed Sensor Signal
D1
BRN
882
D2
WHT
883
RH Rear Wheel Speed Sensor Return
D2
WHT
883
D3
BRN
241
D3
BRN
241
D4-D5
Not Used
D4-D5
Not Used
D6
WHT
1390
D6
WHT
1390
D7
BLK
884
LH Rear Wheel Speed Sensor Signal
D7
BLK
884
D8
RED
885
LH Rear Wheel Speed Sensor Return
D8
RED
885
  #8 (permalink)
Old 12-27-07, 08:44 AM
Casino Cash: $2200
Nice to see that when they produced a $54,000 car in 1999 they skipped a $5 backshell for this connector, or even 50 cents of electical tape and wire loom.
  #9 (permalink)
Old 12-27-07, 09:16 AM
ewill3rd's Avatar
Cadillac Technician
Cadillac(s): none
View ewill3rd's Photo Album
Casino Cash: $16942
That is C101 alright. It may not be pretty but it works just fine.
I think that is a Packard Electric connector, it doesn't look like much but it is what I refer to as a "weatherpack" connection. It has a seal on each wire to prevent water intrusion. There is a lock on it to hold the connection tight and honestly we rarely have trouble with it.
The picture shows it dangling in the air, it should be hooked on a bracket or clip on the side of the strut tower, that might make it look cleaner and you can always kind of squeeeze all the wires together and wrap some electrical tape around the harness to make it look nicer.
It looks like someone has been messing with it, what kind of work has been done on this car?
Views expressed by the author of this post do not necessarily represent those of the Lindsay Automotive Group.
  #10 (permalink)
Old 12-27-07, 09:50 AM
submariner409's Avatar
Casino Cash: $20694
Crown Vic's car is the one with the "reman" strange engine with strange lineage, with strange symptoms which never seems to run correctly. I think his Dad or an associate did the job and it apparently hasn't been right since.
  #11 (permalink)
Old 12-27-07, 02:54 PM
Gearheaad43's Avatar
Cadillac(s): 1997 Polo Green Cadillac Seville STS
View Gearheaad43's Photo Album
Casino Cash: $1272
Geez I was thinking there should be some kind of weather pak on the backside of that C101!!!
eWill3rd, did you happen to read that post about the new dude with s '93 Deville that has a werido problem of stalling every time he turns on the HVAC????.. I'm curious as to what you think the diagnosis would be.
  #12 (permalink)
Old 12-27-07, 04:32 PM
Cadillac(s): 98 sls
Casino Cash: $5564
yep, its a reman or something
who knows.
Either way i ended up securing it to the strut tower.
  #13 (permalink)
Old 12-27-07, 06:22 PM
Zeeee-yaaaa
Casino Cash: $12230
i didnt mean no offense man
pcm plug is huge thats way to small to be one
and i was laughin cuz it seems every other day you have an issue with that SLS
  #14 (permalink)
Old 12-27-07, 07:36 PM
Cadillac(s): 98 sls
Casino Cash: $5564
quick question, how many RPMs do you turn in 4th at 60 MPH?
  #15 (permalink)
Old 12-27-07, 09:17 PM
Casino Cash: $20694
You need to find your final drive ratio (3:11 or 3:71), because answers from several different vehicles will be meaningless unless you know which ratio they're driving. (......and the rpm will change depending on whether you're in 4th or 4th with torque converter lockup (D).) Your transmission has 4 primary speeds as well as convertor lockup for "5th" or OD.
Tags: , , , , ,
botched, connector, pcm, trans
