Cadillac Forums: Bad Downshift, Floor Vibrates, Whine and Airplane Noise...
Old 12-16-07, 08:36 PM
Cadillac(s): 1996 STS (174,000) Arnott Struts, 18x8 Elbrus Rims, Eibach
View lbwd's Photo Album
Casino Cash: $5567
I guess I let it get bad. My car makes an airplane noise when I hit about 40 MPH +. I was doing 90 and still heard it. It didn't used to do it at 90. When it makes this noise, I can also feel a little vibration on the floor (passenger noticed it first).
Other problems: when I hit the throttle hard (WOT) it doesn't down shift properly, thus taking a second to kick in. I also noticed that in the cold weather, I was getting a little whine when I accelerated normally or gently.
MAF, vacuum, any ideas? I don't know how to fix this stuff but I'd like to know what I'm talking about when I take it in this week. Thanks.
  #2 (permalink)
Old 12-16-07, 08:40 PM
CadillacSTS2003's Avatar
Zeeee-yaaaa
Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC
View CadillacSTS2003's Photo Album
Casino Cash: $12230
Re: Bad Downshift, Floor Vibrates, Whine and Airplane Noise...
woah
what your describing to me sound like on a RWD as rear end whine
perhaps you outta stop beatin the piss outta your poor STS... NAH! lol
hows the fluid is it burnt?
if the wot issue was computer related you almost always get a code
if its mechanical like internal valve body in the tranny, the clutches etc then usually you dont...
i see a tranny in your future...
  #3 (permalink)
Old 12-16-07, 08:45 PM
I~LUV~Caddys8792's Avatar
Casino Cash: $21797
Maybe they're two seperate issues. The first one sounds rather like a wheel bearing.
-Chad
From all of these signs saying sorry but we're closed
All the way down the telegraph road
-Dire Straits, Telegraph Road. 1982
  #4 (permalink)
Old 12-16-07, 08:49 PM
Zeeee-yaaaa
Casino Cash: $12230
wheel bearings have sensors in all 92+ Sevilles (im not familiar with previous gen ones)
when one goes your greeted by one of several messages depending on year
Speed Limited to 90
Stability Reduced
Service Stability Sys
Service Steering Sys
not to mention ALWAYS an ABS and T/C lamp
dumb q because i know you know better than to ask without checking 1st lbwd but did you pull the codes?
  #5 (permalink)
Old 12-16-07, 09:48 PM
Casino Cash: $5567
I have no codes. Just the SES light due to exhaust manifold or something. Another thing to have looked at. If it's going to cost much, I'm trashing it and going with something else. We'll see what happens.
  #6 (permalink)
Old 12-16-07, 10:45 PM
Casino Cash: $21797
Speed Limited to 90
Stability Reduced
Oh, whoa that's cool!
  #7 (permalink)
Old 12-16-07, 11:10 PM
Zeeee-yaaaa
Casino Cash: $12230
not really
with ABS and T/C lamp you lose 1st gear, you cant even manually put it in 1st to get 1st gear.
  #8 (permalink)
Old 12-17-07, 10:10 AM
Gearheaad43's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 1997 Polo Green Cadillac Seville STS
View Gearheaad43's Photo Album
Casino Cash: $1272
I'm gonna say "The first one sounds rather like a wheel bearing."
X2 Might not throw a code if it's not bad enough yet. Check CV Axles
  #9 (permalink)
Old 12-17-07, 10:44 AM
mtflight's Avatar
Cadillac(s): 2003 White Diamond DHS
View mtflight's Photo Album
Casino Cash: $4780
check the color/smell/level of the transaxle fluid. To check the level... park on a level surface, go through each gear setting on the shifter for a few seconds, then back to park... leave the car on and check level with engine running. Check for the following BAD conditions:
1- foaming
2- dark brown or black
3- burnt smelling
You may get away with replacing the fluid (idle the car and let the pump empty it, by disconnecting the top tranny cooler line, while you put new fluid in--stop when it comes out bright red). Although it could be debris on the screen causing the whine.
Tags: , , , , , ,
airplane, bad, downshift, floor, noise, vibrates, whine
