| Cadillac Seville / Cadillac Eldorado Forum Forum for discussions regarding the past Seville and Eldorado. | Cadillac Forums: Code questions
10-25-07, 01:13 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Code questions Hello, new to the site and new to the world of cadillacs. Sorry about the length just have a few questions. I just picked up a 1998 seville sts with 109000. I am only getting heat on the passenger side. So i ran the codes and i got B1340 - air mix door one movement. Is this under the dash on the drivers side, and what should I look for? I also have a few other codes that i need help with. I am getting the c1722 and c1727 - right and left rear damper open circuit. I think that is because the rear shocks are passive (I have resistors that suposedly will fix that but not sure). And lastly, I have c1738 exhaust solenoid short to gnd. Any help with any of these is greatly appriciated. Oh, and I searched, just didn't find what i needed  . THANKS!!!!  |
10-25-07, 01:52 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Code questions The air mix door actuator are on the passenger side. One is accessible after removing the glove box and the other from underneath. Run the temp up and down while watching them and you'll see which is not moving. Might just be a disconnected linkage. If not then a bad actuator. Quote: |
| Correct.
C1738 is regarding the ELC (Electronic Level Control) compressor. The exhaust solenoid is serviceable I believe. It is behind the RR wheel. |
10-25-07, 02:19 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Code questions Thanks for the quick reply! Ok, so the bot actuators are on the passenger side? I will try to get it all fixed this weekend. Appriciate the info. |
12-01-07, 05:06 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Code questions Well I just now got to this. I can only find the one actuator and its the one for the pass side. I removed the glove box and looked evrywhere from underneath and i still can't find it. I removed the plastic panel underneath and the carpeted panel near the radio. WHERE IS THIS THING? |
12-01-07, 05:38 PM
| | Cadillac Owners Member Cadillac(s): 98 STS | | Join Date: Sep 2005 Location: satellite beach fl | | | Re: Code questions on a 98 the driver side actuator door is on the driver side |
12-01-07, 09:19 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Code questions I thought they where both on the passengers side. They where on my '97 Deville. Assumed they where the same. Sorry if I led you astray. |
12-01-07, 11:31 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Code questions Alright well i will give it another look tomorrow. Now im dealing with a bigger problem. It snowed for the first time and when i try to drive my car, my front end shakes and makes clunking noises. It feels like the wheels are going to fall off. I am not having good luck with this car. |
12-03-07, 01:06 AM
| | Cadillac Owners Member Cadillac(s): 95 Sedan DeVille | | Join Date: Oct 2007 Location: wyoming | | | Re: Code questions It might have to do with your traction control, try shutting it off, button is in glove box. |
12-03-07, 07:56 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Code questions Yea I actually thought about that, but it was just so noticable I figured something was wrong. But, when I went to drive it the next morning..... it was fine and hasn't done it since. I never found time to work on MY car again (brothers ball joint) so hopefully I can find that actuator under the driverside..thanks for all the help everyone |
12-03-07, 09:06 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2001 STS | | Join Date: Oct 2003 Location: Ontario | | | Re: Code questions Quote:
Originally Posted by philly_blunt Alright well i will give it another look tomorrow. Now im dealing with a bigger problem. It snowed for the first time and when i try to drive my car, my front end shakes and makes clunking noises. It feels like the wheels are going to fall off. I am not having good luck with this car. | There is the possibility that you had ice and crap caught up in the wheel wells and every where. I actually had an experience like that once. Thought the whole front end was gonna come apart.
Could or couldnt be what happened to you. If it happens again when its snowy, take a look at it once you park to see if its all jammed up. |
12-05-07, 07:39 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Code questions Well it snowed again and the same thing happened. I checked the wheels for a build up of snow or ice and found nothing. But I did notice that it only does it when I am driving on the snow. Once I get out to the salted roads, all is good and it drives fine. I tried turning my traction off but it still did the same thing. It feels like the front pass side wheel is falling off or going to collapse! |
12-05-07, 08:43 AM
| | N* Headgasket Survivor Cadillac(s): 99 Z-rated STS, 90 Coupe Deville (sold) | | Join Date: Apr 2007 Location: The Ocean State Age: 46 | | | Re: Code questions Check codes again. Possibly an ABS issue? Although you should get an ABS light if there is a problem. I would also have suspected traction control if you hadn't tried turning it off. No messages on the DIC when it happens? |
12-05-07, 11:45 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Code questions Nope no message on the DIC no ABS light, I will have to run the codes again. |
12-09-07, 09:49 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2001 STS | | Join Date: Oct 2003 Location: Ontario | | | Re: Code questions Stab in the dark here.....but is the tire pressure ok on that side ?
Or hows bout a ball joint or control arm maybe ? Nether one of those will throw a code. |
12-10-07, 03:07 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Code questions Well, not sure what it was but it hasn't done it since that second time and its snowed since then...sooo hopefully it was just angry because it was its first time ever seeing snow... lol | | Cadillac Discussion Tools | | |
Censor is ON | | | |
