Cadillac Forums: 1999 STS dies at intersections
Old 10-04-07, 03:00 PM
View noobie's Photo Album
Casino Cash: $310
Hi, I have a 1999 Cadillac STS that has an ongoing problem when I come to a traffic stop. Sometimes the engine cuts off, before it does, it starts to jerk a bit, some other times it jerks but doesn't die. It doesn't throw any engine code so I have no clue. I'm thinking of fuel filter. What do you guys suggest?
Thanks.
  #2 (permalink)
Old 10-04-07, 03:20 PM
Cadillac(s): 98 Seville SLS *Lord Vadar*
View JC316's Photo Album
Casino Cash: $3340
Re: 1999 STS dies at intersections
If it were the fuel filter, I would think that it would die on the highway from lack of fuel.
  #3 (permalink)
Old 10-04-07, 03:23 PM
CadillacSTS2003's Avatar
Zeeee-yaaaa
Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC
View CadillacSTS2003's Photo Album
Casino Cash: $12230
its a 99 but still possible and usually they throw codes
but maybe crank position sensors
  #4 (permalink)
Old 10-04-07, 03:29 PM
RunningOnEMT's Avatar
Cadillac Owners Master
Cadillac(s): 05 Redline CTS-V
View RunningOnEMT's Photo Album
Casino Cash: $8089
does it herk and jerk on throttle up ... and stutter when you just blip the throttle
might be a high resistance connection in the ignition
melted connector, bad wire, bad plug...
if it was a fuel filter bad enough to shut the car off he'd get a lean bank code first
  #5 (permalink)
Old 10-04-07, 07:28 PM
Casino Cash: $310
Once I remove the brake and the car starts rolling, it won't die. It only dies when it's fully stop. The car revs up just fine, no jerk or herk when throttle is applied. No stutter when throttle is removed.
I guess it's not fuel filter then. Some mechanics said it was a fuel filter.
  #6 (permalink)
Old 10-04-07, 07:36 PM
submariner409's Avatar
Casino Cash: $20694
Search for CKP or Crankshaft Position Sensor. The low-rpm stall or shudder is common in a CKP fault. There was a TSB on them, and quite a few were replaced under warranties, from '99 through '02. Have your GM dealer pull the service history for your VIN. A CKP service, by GM, will be there. There are 2, A and B. Replace them both. The bad ones are stamped "Mexico", while the service replacements are stamped "Japan". AJxtcman had the date codes in here about 6 months ago. The threads will give you the online GM dealers to order from.
  #7 (permalink)
Old 10-04-07, 07:38 PM
Zeeee-yaaaa
Casino Cash: $12230
2003 also had that problem
mine were replaced with only 1200 miles...
  #8 (permalink)
Old 10-04-07, 09:06 PM
View Ranger's Photo Album
Casino Cash: $24241
It's not the fuel filter. Fuel filter would cause a problem at high fuel flow (WOT or highway). Sounds like your TCC is not disengaging. It's like trying to stop a car with a standard trans without stepping on the clutch. Pull the DTC's.
  #9 (permalink)
Old 10-05-07, 12:29 PM
Casino Cash: $8089
see if your TCC lockup clutch is disengaging... there should be a lead into the trans put a multimeter on it and see if it clicks on and off ...
  #10 (permalink)
Old 10-05-07, 02:02 PM
Casino Cash: $310
It died 2 times on me this morning when driving to a gas station. I have to use both of my feet to keep it from dying, one foot on the brake pedal, and one foot on the gas pedal. If I apply a tiny pressure on the gas pedal, the car won't die, but if I release the gas, it would start to jerk.
Do you guys still think it's TCC or Crankshaft position sensor?
  #11 (permalink)
Old 10-05-07, 02:29 PM
Cadillac(s): Cadillac Seville sls 1999
View 99 Seville Caddy's Photo Album
Casino Cash: $385
What about the throttle position sensor or the idle speed motor?
  #12 (permalink)
Old 10-05-07, 03:28 PM
Casino Cash: $310
Yeah, I'm looking at these 2 right now. Looks like my throttle body is also full of carbons.
  #13 (permalink)
Old 10-05-07, 10:42 PM
Casino Cash: $24241
Clean the TB. The ISC air passage may be carboned closed.
  #14 (permalink)
Old 10-07-07, 05:23 AM
View saltr's Photo Album
Casino Cash: $250
My 02 Eldo had very similar symptoms to yours. It finally quit one day long enough to trip a code. I believe it was P0385,ended up replacing both crank position sensors,just as submariner409 mentions in his post.-saltr
  #15 (permalink)
Old 10-07-07, 07:57 AM
Cadillac(s): 2000 Seville STS
View BigBoy_4005's Photo Album
Casino Cash: $375
What about a stuck EGR valve? I learned (while goofing around with output overrides using a scan tool ) that it sounds odd, actually like a lopey stock car, when the EGR is open at idle.....Until it dies that is.
Tags: , , ,
1999, dies, intersections, sts
