70 MPH Vibration
Results 1 to 6 of 6
Cadillac Seville / Cadillac Eldorado Forum Discussion, 70 MPH Vibration in Past Cadillac Vehicle Discussion; Several guys I work with have 99-01 STS's that all have (had) 60-70 mph vibrations problems. The guy with the ...
    dave nygren is offline Cadillac Owners Member
    May 2003
    3
    70 MPH Vibration
    Several guys I work with have 99-01 STS's that all have (had) 60-70 mph vibrations problems. The guy with the 01 has had the dealer work hard to resolve the problem with rotors, several sets of tires, and even control arm replacements. Most of the focus has been on the front end. The dealer even did the force balance and tire sorting thing with no improvement. I do most of the work myself on my '99 and I have been able to significantly improve the issue with ... it sounds wierd ... REAR rotor tuning. I call it tuning because the rotors are within spec, but making them closer to perfect seems to make the only difference. I also had to loosen the parking brake cable on mine which helped. The guy with the '00 just bought his so don't know how bad his is.
    Bottom line: all three seem to have the same issue and I don't think it's tires. I think it's possibly the CVRSS system responce tuning up with brake rotor issues at the 60-70 mph speed and 'allowing' the bounce or resonation.
    Any thoughts????
    Katshot's Avatar
    Katshot is offline Cadillac Owners Master
    Jan 2003
    Newtown, PA
    58
    6,472
    That's a first. Any issue like that I've ever heard of was resolved with the road-force balancing. If the vibration is at a "specific" speed as you say, if probably is a resonant vibration that could be almost anything moving at the time acting directly (or even indirectly) on another part of the car. It could even be the exhaust.
    Brett's Avatar
    Brett is offline Watching the Watchers
    Jan 2003
    Tampa
    43
    5,966
    sounds like my problem
    May 2003
    3
    Some more on a site that the '01 owner found on the problem ...
    http://www.carsurvey.org/viewcomments_review_19040.html
    Brett's Avatar
    Jan 2003
    Tampa
    43
    5,966
    sounds like im screwed, oh well, its not a big deal
    Chuck C's Avatar
    Chuck C is offline Cadillac Owners Connoisseur
    Jan 2003
    NE Ohio
    1,531
    i had that at pone point...i'll let you know if i still have it
  9. Remove Advertisements
