  Follow CadillacOwners on Twitter
Cadillac Forums: 98 SLS overheating...
Old 07-01-07, 09:55 PM
chrislikescrazy's Avatar
Cadillac(s): 1998 Cadillac Seville SLS
View chrislikescrazy's Photo Album
Casino Cash: $250
Angry 98 SLS overheating...
I have a 98 seville sls, it overheats randomly and loses coolant.
When it heats up it pukes coolant through the reservoir cap. I did a compression test, all the cylinders read normal. I replaced the thermostat and there are no visible leaks on coolant system.
someone help i cant think of anything else it could be.
  #2 (permalink)
Old 07-01-07, 09:59 PM
View Ranger's Photo Album
Casino Cash: $27171
Re: 98 SLS overheating...
Compression test won't tell you anything. Do a cylinder pressure test. Check the purge line, tensioner, thermostat and cap.
  #3 (permalink)
Old 07-01-07, 10:07 PM
iametarq's Avatar
Cadillac(s): 1998 SLS - 160,000 mi
View iametarq's Photo Album
Casino Cash: $11261
How long between coolant losses and refills? I could not find a leak for the longest time, and with the help of Ranger, it appears to (hopefully) just be the gasket for the water pump cover...
  #4 (permalink)
Old 07-02-07, 12:52 AM
Cadillac(s): 94 ETC,97 STS
View zonie77's Photo Album
Casino Cash: $8579
Ranger, you have to save the answers and repost them. You'll save a lot of typing!
  #5 (permalink)
Old 07-02-07, 01:10 AM
Casino Cash: $27171
Yeah, I should store them. This is getting old fast.
  #6 (permalink)
Old 07-02-07, 01:36 AM
lisekpl's Avatar
Cadillac(s): 1996 STS
View lisekpl's Photo Album
Casino Cash: $350
Also check the fans, make sure they are coming on, or at least at the right time. ALso check your exhaust, and just because you cant see any white smoke doesnt mean you're not burning coolant.
Man, I'm happy I'm past that whole nightmare, it's nice to have a car that doesn't overheat anymore.
  #7 (permalink)
Old 07-04-07, 03:53 PM
Casino Cash: $250
how do i test the purge line
  #8 (permalink)
Old 07-04-07, 06:42 PM
Casino Cash: $27171
Pull the line off of the surge tank at idle (engine cold). It should flow coolant. Flow will increase with RPM. If it flows coolant it is OK. If not, locate and clear the obstruction.
  #9 (permalink)
Old 07-15-07, 12:54 PM
Casino Cash: $250
checked the purge line and its flowing constant and increases with RPMs. i hear fluids sloshing around whenever i accelerate or turn. the only thing i have not checked or changed is the coolant cap.
  #10 (permalink)
Old 07-15-07, 10:04 PM
Casino Cash: $27171
Sounds like you have air in the heater core.
  #11 (permalink)
Old 07-16-07, 06:34 PM
Casino Cash: $250
i replaced the cap and it still will shoot about 3/4 up the gauge and randomly drop to normal if it is the heater core how do i deal with that
  #12 (permalink)
Old 07-16-07, 08:23 PM
ej2000n's Avatar
Cadillac(s): 2000 STS
View ej2000n's Photo Album
Casino Cash: $665
Best bet would be to take it to a shop and get it tested. overheating is never a good thing and will only lead to more expensive repairs if you continue to drive the car.
  #13 (permalink)
Old 07-16-07, 11:25 PM
Casino Cash: $8579
There are plenty of things you haven't checked yet.
Did you check the water pump belt? tensioner? radiator plugged? Coolant for exhaust gases? Crossover for leaks? Water pump for leaks?
Tags: ,
overheating, sls
attach your bluetooth cell phone to onstar
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
