Cadillac Forums: I lent my caddy to my older sis...
  #16 (permalink)
Old 06-25-07, 10:34 AM
Cadillac(s): 1996 Deville (sold), 2000 Mustang GT
View misfit6794's Photo Album
Casino Cash: $9379
Re: I lent my caddy to my older sis...
There could be a clog somewhere since your cap isn't getting hot, flush the coolant, fill it top the proper level, watch it like a hawk.
  #17 (permalink)
Old 06-25-07, 12:34 PM
tpis15's Avatar
Cadillac(s): 95 aurora + 97 seville sls
View tpis15's Photo Album
Casino Cash: $560
I may be wrong but I belive the coolant won't flow properly without a thermostat on a northstar. My Aurora was running hot so I took the thermostat out. The car was worse without it so I put in a new stant thermostat and all was fine.
  #18 (permalink)
Old 06-25-07, 12:42 PM
clarkz71's Avatar
Cadillac(s): 1994 Mercedes E420 / 1995 Eldorado/ 2006 Yamaha R1 LE
View clarkz71's Photo Album
Casino Cash: $1100
I agree, put in a new thermostat, after filling it with coolant pull the purge line off the surge tank and verify it flows/dribbles coolant.
  #19 (permalink)
Old 06-25-07, 01:31 PM
WarrenJ's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 2001 ETC Sequoia
View WarrenJ's Photo Album
Casino Cash: $510
Originally Posted by Krashed989 View Post
I let the engine run and watched the temp gauge climb fairly rapidly untill it reached 236 and I decided to shut it off. But then I went to remove the cap from the resovior to release the pressure so it would cool down faster and I found that the cap was actually cold to the touch! Not only was the cap cold, the engine wasn't hot either . . .
You sure make it sound like coolant is NOT circulating.
Regards,
Warren
  #20 (permalink)
Old 06-25-07, 03:49 PM
1997BlackETC's Avatar
Cadillac(s): 1997 Eldorado ETC
View 1997BlackETC's Photo Album
Casino Cash: $250
You sure the waterpump is spinning being drivin by the narrow waterpump belt? Maybe the impeller of the waterpump is messed up?
  #21 (permalink)
Old 06-25-07, 08:37 PM
View Ranger's Photo Album
Casino Cash: $24266
I am pretty sure this is correct. It will run hotter without a thermostat.
  #22 (permalink)
Old 06-25-07, 11:27 PM
Krashed989's Avatar
Cadillac(s): 94 Eldorado, and a totaled z rated STS
View Krashed989's Photo Album
Casino Cash: $10983
Now, the two coolant pipes around the back of the engine were replaced with rubber hoses about 4-5 years ago. Although, I haven't yet experienced any problems with that change, they do arch up above the level of the resovior cap and if they have air in them could pose a restriction. That's my next educated guess, but I would think the waterpump should have enough power to push that bubble through and purge it. I mean it's never given me problems before.
It's fixed!!! Believe it or not, what I guessed above was actually right on. When I changed the radiator the lower rad hose clamp was really hard to get tight because of the angle of the spicket. I thought it was on there good but apparently it was slowly leaking, and that caused it to overheat and let the coolant level get really low. Then after refilling the coolant (and tightening that hose clamp better) an air bubble remained in those two hoses, restricting the flow. Today I was able to get the air out of the system and now it's all better.
And the thermostat I still need to put back in there. It actually runs about 20 degrees cooler than normal (190 F rather than 210 F) with the thermostat out.
  #23 (permalink)
Old 06-25-07, 11:36 PM
Casino Cash: $24266
Now go apologize to your sister.
  #24 (permalink)
Old 06-26-07, 03:45 AM
Krashed989's Avatar
Casino Cash: $10983
LOL... I have nothing to apologise about. I held my tongue and didn't pass the blame to anyone.
Although I would like to thank you and everyone in this thread for helping me. I appreciate it a lot!
Tags: , , ,
caddy, lent, older, sis
