I saw another post earlier this year where Frank T described these components and I know he would know how they should route.... the Helms does not show the routing....and I cannot find it anywhere... Had one guy said he had the diagram and he sent me one, but it does not make it happen..
The reason this line is unhooked is because I had to install an engine in this vehicle after another person had removed the original because of crack block. I finally got everything together (heck of a job) but I could not find where to hook the EVAP canister purge line....likely because I got the routing on the switch and solenoid wrong but I still don't know how to correct and I think it has to be fairly simple.... If I could just see one... If anyone knows where a good shot of the rear bank of a 4.6 (without cover) is I should be able to tell from that....
I don't know where the Canister purge line hooks up --- on my (4.6) the canister line is not connected... the vac sw has two ports for sure and a third that is a facsimilie I think...the small port at the base of the electric connector socket loops to the bottom port (where there is a tee) on the Solenoid and the tee then loops back to the larger port on the Switch making what appears to me to be a sensless loop??? then the upper port on the Solenoid connects to the manifold --- seemingly the vacuum sorce.... So where is the purge from the canister supposed to connect? -- the bottom port (where the tee is on mine) of the solenoid has "CAN" stamped vertically on it and I have to believe that is where the purge from the can should go...but how does the others route??? I have Helms and they simply do not show enough detail on this....
I am posting this pic (hard to see but if you know it you can tell) that shows how the routing is now (again I am sure it is wrong) but I need to know what to do to hook the purge line somewhere........
