| Cadillac Seville / Cadillac Eldorado Forum Forum for discussions regarding the past Seville and Eldorado. | Cadillac Forums: How to- Harmonic Balancer
05-14-07, 10:42 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | How to- Harmonic Balancer How do i change a harmonic balancer from a 1997 cadillac eldorado, i probably can figure it out me n my friend are going to try to do it, but where can i get the tool for it for cheap? and ho to do it? thanks for replys |
05-14-07, 02:23 PM
| | Cadillac Owners Connoisseur Cadillac(s): 98 Seville SLS *Lord Vadar* | | Join Date: Mar 2005 Location: DFW Texas Age: 23 | | | Re: How to- Harmonic Balancer Well, you are going to need a 3 jaw puller, a big ass breaker bar, and something to hold the flywheel.
Basically getting the bolt out is THE hardest part. Someone told me that they secured the breaker bar and cranked the engine over, I am not sure how well that would work, so I can't recommend it.
Otherwise, you will either A, have to pull the intake and starter, or B go underneath to the inspection plate. |
05-14-07, 06:29 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: How to- Harmonic Balancer Be sure to torque the new one to proper spec's as it drives the oil pump. Failure to do so will cause the pump to slip and thus low oil pressure. I don't remember what the torque spec is , but it is quite high (300ft/lb +). |
05-14-07, 08:52 PM
|  | Cadillac Owners Fanatic Cadillac(s): 1996 STS | | Join Date: Aug 2006 Location: Chicago, IL | | | Re: How to- Harmonic Balancer Ranger's right, use should re-torque exactly to specs. I just did it, if I remember correctly they were 37 lbs ft and 120' degrees. I will check it after work. Some people say that you shouldnt reuse the old bolt, but I just put some loc tite and went with it. |
05-14-07, 10:21 PM
|  | Cadillac Owners Fanatic Cadillac(s): '93 STS | | Join Date: Jul 2005 Location: Corona Del Mar, Ca. Age: 54 | | | Re: How to- Harmonic Balancer Replacing my North*, I learned all about which bolts are 'stretch bolts'.... use them once & when removed, throw away.
One hint to determine if the bolt is a 'stretch', is the torque spec. They describe a light torque, then a DEGREE of turn to finish. ( 25lb. + 15 ' )
Careful, ...a complete turn is 360 degrees, so if it requires 15 degree, figure the amount.
I wouldn't play with a hard to reach bolt.... toss it. |
05-15-07, 03:10 AM
|  | Cadillac Owners Fanatic Cadillac(s): 1996 STS | | Join Date: Aug 2006 Location: Chicago, IL | | | Re: How to- Harmonic Balancer To confirm, the dampener bolt should be tightened to 37 lb. ft and then 120 degrees. To do the final step, just use the position of any two spokes on the dampener (since they are 120 degrees apart) and turn so that your starting spoke is in place of the other spoke after the turn. |
05-15-07, 02:02 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: How to- Harmonic Balancer  ok ill try to understang exactly what you guys are saying, its kind of hard since i am just starting to work on cars, terms and whatnot, but thanks for your replys. me and my friend i beleive are mechanically talented to figure out how to- just not with names as of yet. but thanks |
05-15-07, 09:24 PM
|  | Cadillac Owners Fanatic Cadillac(s): '93 STS | | Join Date: Jul 2005 Location: Corona Del Mar, Ca. Age: 54 | | | Re: How to- Harmonic Balancer Quote:
Originally Posted by Coreyned  ok ill try to understang exactly what you guys are saying, its kind of hard since i am just starting to work on cars, terms and whatnot, but thanks for your replys. me and my friend i beleive are mechanically talented to figure out how to- just not with names as of yet. but thanks | Some details can be confusing........ I suggest you do what I have done in the past.... Ask a mechanic or have him show you.
If you want to learn something new, there is no such thing as a dumb question. Most mechanics will understand that. Good luck! | | Cadillac Discussion Tools | | |
Censor is ON | | | |
