End links replacement
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By MoistCabbage
Cadillac Seville / Cadillac Eldorado Forum Discussion, End links replacement in Past Cadillac Vehicle Discussion; I bought a new set of stabilizer end links for my 99 Eldo. They are noisy when hitting bumps. What ...
    Rag64top is offline Cadillac Owners Fanatic
    Automobile(s): 03 Deville DTS, 07 Escalade, 02 Yukon Denali, 64 Impala Conv
    Aug 2004
    NH
    113
    What is the deal with getting these off?
    I can get the bolts off, but the studs are stuck in the mounting bracket on the top, and the stabilizer bar on the other end. Do I need a tie rod removal tool?
    Endless beating with a hammer has no effect.
    Any idea's? Do I have to heat them up?
    Is this a comon thing? I'm still on the first side....arghhhh
    Peace
    Rags
    68
    81,917
    Re: End links replacement
    Is the weight on the suspension or is the suspension hanging?
    Aug 2004
    NH
    113
    It's hanging, should I try jacking up the suspension while its up
    on the blocks to take the tension off?
    JC316 is offline Cadillac Owners Connoisseur
    Mar 2005
    DFW Texas
    30
    1,406
    I used a small ball joint seperator and a hammer, they popped right off.
    FloorGod is offline Cadillac Owners Member
    Automobile(s): 1994 SLS, 1998 STS, 2002 STS...subject to change w/o notice.
    Apr 2007
    Colorado
    19
    Quote Originally Posted by Rag64top View Post
    Yes. Even if you beat on them long enough to pop it out (possible), your suspension will drop then, and you'll have to jack it up to get the new one in.
    Jack it up...5 minutes...done!
    Raze's Avatar
    Raze is offline Cadillac Owners Enthusiast
    Automobile(s): 90 Eldo -SOLD-, 98 ETC -SOLD-, 86 XR4Ti Track Car, 07 Ranger
    May 2004
    Atlanta, GA
    34
    963
    there's a much easier way, get a 2 inch or so pulley puller, get larger bolts so you can adjust the arm spacing to any length, slide it over the attach points, use a small C-clamp to clamp down the arms so they don't slide off the strut attach point and then just ratchet down on it and they'll pop right off.
    Otherwise buy a ball joint seperator 81NL2149N from jcwhitney it'll just take some time to get
    Aug 2004
    NH
    113
    Quote Originally Posted by FloorGod View Post
    I think the only thing that will drop is the stabilizer bar itself, no big deal, but I will try to take some of the pressure off it, and see how that works.
    I just got back from the tool store, and now am well armed with a set of various sized ball joint tools, (pickle forks), and a 2" pitman arm puller, so
    I can try like Raze said. I also got a tank of map gas, if none of the above works, I'll try putting some heat to it. Good idea about clamping down the puller with c clamps, I was afraid it would slip off, this will fix that.
    Here is the pitman arm puller that I got, it is just 2" total inside measurment (1.5" gap), so should fit over the bracket where the end links bolts up to, and hopefully will work on the bar end also.
    http://cgi.ebay.com/ebaymotors/ws/eB...8086754&rd=1,1
    Thanks for all the sugestions, I appreciate all the help.
    Sometime I wonder why I start these projects myself, and when I do , I have
    a greater respect for mechanics, and all the tricks they know, and the tools they have. Every time something seems simple, its not.
    Peace
    Rags
    Scottsdale95 is offline Cadillac Owners Member
    Automobile(s): 2002 Eldorado ESC White Diamond
    Oct 2012
    9
    Harbor Freight tool 99849 works perfect for this job!
    http://www.harborfreight.com/3-4-qua...tor-99849.html
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    6 year old thread. I think that's this weeks record .
    basscatt likes this.
  12. Remove Advertisements
