| Cadillac Seville / Cadillac Eldorado Forum Forum for discussions regarding the past Seville and Eldorado. | Cadillac Forums: My Little List of Problems :: Your Input Requested
04-17-07, 02:43 PM
| | Cadillac Owners Connoisseur Cadillac(s): 1996 STS (174,000) Arnott Struts, 18x8 Elbrus Rims, Eibach | | Join Date: May 2006 Location: Missouri | | | My Little List of Problems :: Your Input Requested One -- my list isn't too large -- it's short.
Two -- I have no codes and these aren't huge issues. Let's begin...
My oil light (in the speedometer) blinks when I am stopped or idling and I had discussed this before -- we came to the conclusion that's it has to be the switch. Good. Solved.
Now, I did a short little race today (owned a Jeep by 16 car lengths) and in the process, I smelled a bit of burning oil. This may be typical and no problem. Hopefully so. My engine temp meter is very SLIGHTLY to the right of the mid point... going in for a coolant change soon.
** Last of all, my transmission seems to run a little rough at 45 MPH and under. Does this mean, YES, I need to take it to the shop and have the trans fluid changed?
Mileage: 160,000 Miles
1996 Seville STS
Oil Life: 84% Thanks!  |
04-17-07, 02:59 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 90 Eldo -SOLD-, 98 ETC -SOLD-, 86 XR4Ti Track Car, 07 Ranger | | Join Date: May 2004 Location: Atlanta, GA Age: 27 | | | Re: My Little List of Problems :: Your Input Requested 1) You can have your oil pressure tested by a shop, they can tell you definativley if it's the switch
2) Burning oil under the hood or from the tailpipe? Blowing anything other than black/grey smoke is bad. If you have an oil smell under your car pull the cradle splash guard and check for any visible oil leaks, prolly an oil pan gasket or half case seal, neither you can do much about unless you drop the cradle and pull the engine
3) What do you mean by rough transmission? Is it slipping/shifting hard? if so you may need new shift solenoids but you'd prolly be throwing a code. Is the engine running rough which you are 'percieving' through the transmission? if it is that's a whole other problem... |
04-17-07, 03:19 PM
| | Cadillac Owners Connoisseur Cadillac(s): 1996 STS (174,000) Arnott Struts, 18x8 Elbrus Rims, Eibach | | Join Date: May 2006 Location: Missouri | | | Re: My Little List of Problems :: Your Input Requested Thanks!
By rough, I mean that it shifts a lot in the 45 mph and under range. Seems like it shifts more than normal. |
04-17-07, 03:38 PM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: My Little List of Problems :: Your Input Requested a badly leakin half case will cause major issues down the road and will create pressure problems
ewill posted a pic of a N* that destoryed the bottom end due to the "minor" half case seal leak....
and keep in mind we do have the 3:71 tranny
it does shift frimer and more often around that peak hp than you may expect becuase its a lac... |
04-17-07, 11:16 PM
|  | Cadillac Owners Master Cadillac(s): 1989 STS / 2001 DTS / 2002 DTS | | Join Date: Apr 2005 Location: Upstate NY | | | Re: My Little List of Problems :: Your Input Requested I have a question regarding this. My trans after being rebuilt doesn't seem to shift as firm as it used to. There was some talk of the computer getting set to base values during the code clearing process?
What do we know about this? Quote:
__________________ Ownership:
89 STS (1 of 1893) - FOR SALE
02 DTS 01 DTS: Custom installed Volant CAI Custom PCM Body color engine components Cruiser Alloy wheels EBC brakes Eibach springs Corsa exhaust Sportwing Spoiler Semi-custom interior Custom quad Hi-Beams Future Plans: More interior work. Memberships: National and regional Cadillac & LaSalle Club Proud Volunteer - Northstar Tuning Project ---------------------------- |
04-18-07, 06:17 PM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: My Little List of Problems :: Your Input Requested 01+ had performance shifting algorithms
your car may have to "re-learn" your driving styles... |
04-18-07, 08:33 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2001 STS | | Join Date: Oct 2003 Location: Ontario | | | Re: My Little List of Problems :: Your Input Requested We still talkin 01 ^^ Quote:
Originally Posted by lbwd Thanks!
By rough, I mean that it shifts a lot in the 45 mph and under range. Seems like it shifts more than normal. | Mine seems to act as though it may be a bit confused at that lower speed.
Takes the gear though, but seems to feel a little hard and rough. Maybe rough is the wrong term. But does grab in hard. Not clunking hard. But hard just the same.
Have wondered about that myself.
Normal thing ?? |
04-18-07, 08:42 PM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: My Little List of Problems :: Your Input Requested i was answering in regards to codewize |
04-18-07, 10:29 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2001 STS | | Join Date: Oct 2003 Location: Ontario | | | Re: My Little List of Problems :: Your Input Requested Quote:
Originally Posted by CadillacETC1997 01+ had performance shifting algorithms
your car may have to "re-learn" your driving styles... | Is why I asked about the 01s.
As per your reply to Codewize ??
04-18-07, 10:42 PM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: My Little List of Problems :: Your Input Requested startin in 01 STS and DTS came with performance shift algorithms.... |
04-18-07, 11:33 PM
Normal thing ?? | Dont know not bout algorithims myself.
But seein as 01 was brought up.
Talked bout difference in shifting. Felt was relevent to the thread etc....etc......
Dont have an answer to my question is fine.
I believed it was all prelevent to the thread.
Thought I was paying attention ??
Dont want or dont have answere to my Q...then dont......
Sorry for disrupting your privacy.
Have no idea why Im saying sorry other than it appears I had upset you with a question that was releveant within this thread.
Was only askin bout shifting in 01s that was already talked about and I get a reply stating that you were talking to someone else ?????
Excuse me for being in an open forum | | Cadillac Discussion Tools | | |
Censor is ON | | | |
