  Follow CadillacOwners on Twitter
Cadillac Forums: Brake Fluid resevoir float?
Old 04-08-07, 01:15 PM
fpmesiIII's Avatar
Cadillac(s): 1996 Cadillac Seville STS (167k)
View fpmesiIII's Photo Album
Casino Cash: $655
I believe my car's brake fluid float has come disengaged. The Msg check brake fluid level comes on whenever I get the the RPMS up high or when i stop quickly. this problem started a couple days ago. I have been check the brake fluid level and it does not seem to be low.
I disconnected the sensor from the brake fluid resevoir, that did not fix the problem. I also tried fishing around in the resevoir for the float and I coud not find it. What does it look like and what object should I use to fish it out? and how do you replace it?
  #2 (permalink)
Old 04-08-07, 01:36 PM
stevebuick23's Avatar
Cadillac(s): 1997 STS, 2000 L67 Regal Beagle
View stevebuick23's Photo Album
Casino Cash: $277
Re: Brake Fluid resevoir float?
i don't think there is a float. Its just the sensor that reads the fluid level I think.
  #3 (permalink)
Old 04-08-07, 01:43 PM
Cadillac(s): Cadillac
View butch h's Photo Album
Casino Cash: $250
Both my '87, and '94 Sevilles use a fluid level switch-no float.If yours is the same,the wire you disconnected probably is on that switch.
  #4 (permalink)
Old 04-08-07, 02:01 PM
fpmesiIII's Avatar
Casino Cash: $655
i will go out and take a picture of what i disconnected.
  #5 (permalink)
Old 04-08-07, 02:09 PM
Playdrv4me's Avatar
Cadillac(s): Does it have wheels? Odds are I've driven it.
View Playdrv4me's Photo Album
Casino Cash: $10537
At your mileage, the sensor itself probably needs to be replaced. There isnt a "float" in there.
"You ough'ta go and find a brain sale... And find a cheap one, cause you ain't got no trade-in!" - Red Fox
  #6 (permalink)
Old 04-08-07, 02:26 PM
fpmesiIII's Avatar
Casino Cash: $655
Re: Brake Fluid reservoir float?
here is the sensor i disconnected. is this the part that needs to be replaced? it looked very clean.
here is another view of the reservoir, it looks like the fluid is at a adequate level.
  #7 (permalink)
Old 04-08-07, 03:52 PM
Cadillac(s): '98 STS
View JimD's Photo Album
Casino Cash: $20483
If you jumper the two pins on the harness connector, the message will not appear. Temporary fix until you replace the master cylinder or the reservoir.
  #8 (permalink)
Old 04-08-07, 06:28 PM
fpmesiIII's Avatar
Casino Cash: $655
how much does replacing the master cylinder or reservoir cost?
  #9 (permalink)
Old 04-08-07, 06:41 PM
Dadillac's Avatar
Cadillac(s): 2002 Seville SLS
View Dadillac's Photo Album
Casino Cash: $4219
Dude top off the fluid to the MAX line. You are low. And it wouldn't hurt to flush that old dirty nasty fluid. Your brake system will thank you for it.
Don
  #10 (permalink)
Old 04-08-07, 06:56 PM
fpmesiIII's Avatar
Casino Cash: $655
any instructions for flushing the brake fluid? i have never performed that procedure.
  #11 (permalink)
Old 04-08-07, 10:01 PM
View Ranger's Photo Album
Casino Cash: $27171
Suck all the dirty fluid out of the reservoir. Then refill it with fresh DOT 3 brake fluid. Then bleed the brakes at each caliper til clean fluid comes out of each one.
Tags: , , ,
brake, float, fluid, resevoir
attach your bluetooth cell phone to onstar
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
