  Follow CadillacOwners on Twitter
Cadillac Forums: Creaking/clunking noise from front end
Old 04-07-07, 01:30 PM
ejguillot's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 2000 Seville STS
View ejguillot's Photo Album
Casino Cash: $27866
Hello all,
Car: 2000 STS, 101K miles
Current Symptoms: a creaking/cricking/sometimes clunking noise that happens under forward braking only. Braking while going in reverse makes no noise. The creaking is noticeable when braking at most any speed (from walking speed until the wind/road noise covers it). Pushing down on the front end reveals a creak from the front left end.
Previous symptoms: The creaking used to show up when turning the wheels left and right, but replacing the outer tie rod ends helped a lot. The stabilizer bar to control arm links were also replaced, and this mostly eliminated the clunk as well.
Accident history: In December 2006, due to a wet slick road (what happens when a road gets rained on for the first time in 3 months: all the oily stuff collected rises to the surface), overconfidence in the wet grip ability of the Michelin Hydroedge tires, and unfamiliarity with the handling of the STS (in spite of stabilitrak) the following happened:
Taking a right hand turn, I understeered into a concrete curb, HARD (impact speed of about 35 miles an hour). The result: Damage severe enough for me to call the insurance company, in spite of the $1000 deductible. To the credit of Cadillac construction, the STS was still drivable enough for me to limp it home, 7 miles out. he replaced parts included the rim and tire, lower control arm, and engine cradle (which had bent in from the force of the impact).
I'm thinking of the front left strut mount and stabilizer bar bushings as remaining culprits.
Ideas?
  #2 (permalink)
Old 04-07-07, 09:12 PM
View Ranger's Photo Album
Casino Cash: $27171
Re: Creaking/clunking noise from front end
That would be my guess.
  #3 (permalink)
Old 04-08-07, 01:41 PM
stevebuick23's Avatar
Cadillac(s): 1997 STS, 2000 L67 Regal Beagle
View stevebuick23's Photo Album
Casino Cash: $277
The stabilizer bar bushings are usually culprits. I didn't enjoy doing the sway bar bushings, mostly because I was to cheap to go to a dealership to buy them. lol
  #4 (permalink)
Old 04-08-07, 02:04 PM
Playdrv4me's Avatar
Cadillac(s): Does it have wheels? Odds are I've driven it.
View Playdrv4me's Photo Album
Casino Cash: $10537
My guess is lower control arm ball joints... Had the same symptoms on my Mark VIII, replaced the ball joint and it solved the problem.
"You ough'ta go and find a brain sale... And find a cheap one, cause you ain't got no trade-in!" - Red Fox
  #5 (permalink)
Old 04-09-07, 12:41 PM
ejguillot's Avatar
Casino Cash: $27866
RE: The lower control arm ball joints
It's possible that the left front lower control arm ball joint is bad, but very unlikely - due to the accident history mentioned earlier, the lower control arm was replaced 3 months and 5000 miles ago. A bad joint from factory is possible, but unlikely. The right front is a possibility, i'll check on that next time around. A further look at the stabilizer bushings shows some wear, i'll try those next.
As for an alignment, has anybody on this forum tried doing the toe in/out alignment themselves? From a few internet postings I read, the using a string method seems like it would be fairly easy and repeatable.
  #6 (permalink)
Old 04-09-07, 11:44 PM
Cadillac(s): Sedan de Ville, CTS
View z06bigbird's Photo Album
Casino Cash: $5444
I vote on strut bushing.
Ed
  #7 (permalink)
Old 04-12-07, 02:39 PM
ejguillot's Avatar
Casino Cash: $27866
Update: When I had installed the outer tie rod ends, i had not had the opportunity to get a front end alignment done. I finally did a toe in/out alignment a few days ago, and having the correct toe has considerably reduced the remaining creaking & clunking.
I'll be fixing the other parts as time and budget permit.
Thanks all for the advice!
Tags: , , ,
creaking or clunking, end, front, noise
attach your bluetooth cell phone to onstar
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
