| Cadillac Seville / Cadillac Eldorado Forum Forum for discussions regarding the past Seville and Eldorado. | Cadillac Forums: oil pressure. stop engine
04-04-07, 07:51 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2001 DTS, 2000 ETC, 1994 ETC | | Join Date: Mar 2007 Location: Tottenham, Ontario,Canada | | | oil pressure. stop engine So i was driving my way home and this showed up on my DIC "oil pressure low stop engine"
well i pulled over into a parking lot and let it sit and cool down and then i pulled the codes. Nothing came up nothing relating to my problem any way. i started the car back up and the notice was gone. nothing came up nothing. So i drove around the parking lot. I revved the engine to see if it did and thing and then shut it down. Started it back up and still no notice on the DIC. I was 5 mins from home so i drove it to my house.
still nothing on the dic.
what should i do. This hasn't happened to any of my other cars. this is my winter car. So i hope it can still work because we still have snow on the ground.
help any one?
thanks |
04-04-07, 08:03 PM
|  | Super Moderator Cadillac(s): Does it have wheels? Odds are I've driven it. | | Join Date: Nov 2003 Location: TPA / STL Age: 100 | | | Re: oil pressure. stop engine This might sound like a dumb question but... did you check the oil level???
If the oil level is ok, and its holding pressure, I would not worry about it too much. Depending on what kind of driving you were doing, Ive had this come up on a 2000 740iL BMW I had as well when I was driving aggressively, nearly the same message.
What can happen is as the oil is sloshing around during aggressive driving maneuvers, it can slosh away from the sensor and fool the car into thinking its suddely lost its oil pressure. I checked the oil and never saw the message again on my 740.
__________________ "You ough'ta go and find a brain sale... And find a cheap one, cause you ain't got no trade-in!" - Red Fox |
04-04-07, 08:16 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2001 DTS, 2000 ETC, 1994 ETC | | Join Date: Mar 2007 Location: Tottenham, Ontario,Canada | | | Re: oil pressure. stop engine well i drive normal but some times hard.i do drive alot it costs me about 25 dollars in gas money each day to go to work and back. that is a lot of KM
the oil is level is fine i have checked all that. |
04-04-07, 08:22 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: oil pressure. stop engine Sounds like a failing oil pressure switch. It's on the oil filter adapter. Before you replace it, pull the connector and clean it with Brakleen or equivalent. It may just be oily. |
04-04-07, 08:43 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2001 DTS, 2000 ETC, 1994 ETC | | Join Date: Mar 2007 Location: Tottenham, Ontario,Canada | | | Re: oil pressure. stop engine ok switch? what does that do.
and where do i find it .
what is another cleaner? WD40 work. |
04-04-07, 09:02 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: oil pressure. stop engine The oil pressure switch sets the message that you saw to alert you to low oil pressure. It is on the oil filter adapter.
Spray it with an electrical parts cleaner, Brakleen or anything that will wash off oil (assuming that it is oily). WD40 would probably work. |
04-04-07, 09:20 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2001 DTS, 2000 ETC, 1994 ETC | | Join Date: Mar 2007 Location: Tottenham, Ontario,Canada | | | Re: oil pressure. stop engine ok thanks. I am going to buy a new fuel filter as well just in case it will only cost me 10 bucks or so for a K&N filter. and also i called our NAPA and they said they could have a new oil sensor/switch in about 4 days. if that is the problem
so I will clean out the sensor.
where is this located ? |
04-04-07, 09:25 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: oil pressure. stop engine What sensor? Oil pressure switch? see post #6. |
04-04-07, 09:38 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2001 DTS, 2000 ETC, 1994 ETC | | Join Date: Mar 2007 Location: Tottenham, Ontario,Canada | | | Re: oil pressure. stop engine |
04-04-07, 09:39 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2001 DTS, 2000 ETC, 1994 ETC | | Join Date: Mar 2007 Location: Tottenham, Ontario,Canada | | | Re: oil pressure. stop engine i haven't ordered it yet. |
04-04-07, 10:47 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: oil pressure. stop engine Looking at that link reminded me that the pressure switch also puts power to the fuel pump after a certain oil pressure is reached, which is why when the relay fails, it causes long crank times as the engine must build oil pressure to enable the fuel pump. |
04-05-07, 08:02 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 2001 DTS, 2000 ETC, 1994 ETC | | Join Date: Mar 2007 Location: Tottenham, Ontario,Canada | | | Re: oil pressure. stop engine ok. so if the switch doesn't work then it wont tell the pump to pump and there will be no oil circulating.
Ok. I will go and clean it out first and see if that inst the problem.
I drove the car today went about 25 mins with out the light coming one which i guess is a good thing. But if the light comes on then i should stop it even though it is just a switch, because that switch control the oil pump.
thanks man.
you are very smart. |
04-05-07, 08:15 AM
|  | Cadillac Owners Fanatic Cadillac(s): 1996 Cadillac Seville STS | | Join Date: Jul 2005 Location: Ontario Canada Age: 39 | | | Re: oil pressure. stop engine That link points to a "Fuel Pump Pressure Switch"....although it does look the same.  |
04-05-07, 08:32 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 2001 DTS, 2000 ETC, 1994 ETC | | Join Date: Mar 2007 Location: Tottenham, Ontario,Canada | | | Re: oil pressure. stop engine that link comes up as hjust jumble of words
here is the part. does it look like this ? http://www.napaonline.com/masterpage...ressure+Switch |
04-05-07, 12:16 PM
|  | Cold Soaked Cadillac(s): 2006 STS AWD, '95 Ford Ranger | | Join Date: Jul 2004 Location: Fairbanks, Ak Age: 70 | | | Re: oil pressure. stop engine It's been posted a dozen times to only use original equipment oil pressure switches from the dealer because they have a unique calibration. Aftermarket switches will give false alarms.
__________________ Don't mess with Binky Bear! | | Cadillac Discussion Tools | | |
Censor is ON | | | |
