  Follow CadillacOwners on Twitter
Cadillac Forums: Eldorado base vs Eldorado etc
Old 03-13-07, 02:14 PM
Cadillac(s): 98 Eldorado
View Mitch3's Photo Album
Casino Cash: $1626
first off, Yes I know this should be on the suspension forum but I get better response from this forum. My question: Is there that much difference between the base and the ETC Eldorados. I checked some of the strut websites and they list replacements for the ETC but not the base. I've been to three different mechanics and they tell me my base Eldo has to use the OEM suspension parts.
Had my rear shocks replaced but it still rides rough. Had the springs checked and they tell me they are good. They now want to replace the front struts but will only use OEM parts. Does the base Eldo really ride hard. I guess my question is: If the base Eldo really rides rough why should I spend another grand to make it ride better? I've been running my Bridgestone Potenza G009 tires at 35 psi hot. Maybe I should lower the pressure to 32 hot. Any thoughts?
  #2 (permalink)
Old 03-13-07, 03:54 PM
jadcock's Avatar
Cadillac(s): White Diamond 2001 STS
View jadcock's Photo Album
Casino Cash: $325
Re: Eldorado base vs Eldorado etc
For a 1998, the ETC uses active (electronic) front struts and the base Eldorado uses passive (conventional) front struts. Both use, to my knowledge, rear air shocks as a rear spring supplement (again, ETC an active air shock and the base Eldorado a passive air shock).
Arnott sells replacement struts for both models (active and passive). If you have a base Eldorado, this is what you need (total parts cost less than $500):
http://www.arnottindustries.com/part...id6_pid36.html
If you have an ETC, this is what you need (total parts cost about $600):
http://www.arnottindustries.com/part...id6_pid49.html
Either way, you should be able to put FOUR new struts/shocks on your Eldorado for much less than $1000 (parts).
The Bridgestone Potenza G009 tires are probably relatively firm, being performance tires. You should always set your tire pressure cold (not hot). Start out at 30 psi cold, which is what Cadillac recommends (see the door jamb decal). 30 psi cold would equate to about 32-33 psi hot. 35 psi hot is only about 33 psi cold, which isn't that much over what Cadillac recommends. I typically run 35 psi cold in the front and 30 psi cold in the rear on both of my Sevilles...which is about 37 psi hot front and 32 psi hot rear. But again, set tire pressure COLD.
  #3 (permalink)
Old 03-13-07, 09:42 PM
Raze's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 90 Eldo -SOLD-, 98 ETC -SOLD-, 86 XR4Ti Track Car, 07 Ranger
View Raze's Photo Album
Casino Cash: $5675
I just put the 4 Arnotts on my 98 ETC w/Eibachs, much better ride.
Tags:
base, eldorado
attach your bluetooth cell phone to onstar
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
