  Follow CadillacOwners on Twitter
Cadillac Forums: The Clean Out :: Tips and/or Advice, Please...
Old 03-13-07, 12:18 AM
Cadillac(s): 1996 STS (174,000) Arnott Struts, 18x8 Elbrus Rims, Eibach
View lbwd's Photo Album
Casino Cash: $5797
Post The Clean Out :: Tips and/or Advice, Please...
Hello,
I would like to clean my car out, mechanically, real good for this summer. Please post the best things to do for my 1996 Seville STS with 161,000 miles on it.
I was thinking of have the cooling system serviced... and maybe some of BG's services... fluids checked, but I haven't actually been able to decide exactly what I need to do.
Your posts are appreciated.
Thanks guys!
  #2 (permalink)
Old 03-13-07, 03:26 AM
Mountie's Avatar
Cadillac(s): '93 STS
View Mountie's Photo Album
Casino Cash: $997
Re: The Clean Out :: Tips and/or Advice, Please...
Originally Posted by lbwd View Post
Hello,
Thanks guys!
Replace the serpintine belt ( check pully bearings, etc. when belt removed), have a trusted privatly owned tranny shop change the oil/filter, change the engine oil / filter ( I use syn/blend), fuel filter, coolant - additive pellets, lube job, sparkplugs & wires ( if original)& use elec. plug/boot grease, ....CHECK THE WEAR AREAS ON YOUR RADIATOR HOSES!! I used hose material & tie wraps to pad wear against sharp pionts ( I found the fan shroud 'arms' at the top rubbing against the hose). Check as many hose clamps as you can. ( get a nut driver- it's easier than a screw driver).....air filter - NOT an oiled type!! Refreshen brake fluid as you can, inspect water pump belt. Clean battery.
Check wiring harness for heat related evidence.
That's all I can think of at the moment.
  #3 (permalink)
Old 03-13-07, 11:19 AM
Casino Cash: $5797
Thank you. I'll add it all to my checklist.
  #4 (permalink)
Old 03-13-07, 12:16 PM
EcSTSatic's Avatar
Cadillac(s): 1999 STS - diamond white
View EcSTSatic's Photo Album
Casino Cash: $14445
In addition to what has been mentioned, eyeball your brake system. Look for deteriorated rubber and metal lines, pad thickness, etc. Also have your brake fluid flushed. Over time it absorbs water and other contaminates which damage the system and lower the boiling point.
  #5 (permalink)
Old 03-13-07, 04:22 PM
Casino Cash: $5797
What kind of additives should I consider for my fluids?
  #6 (permalink)
Old 03-13-07, 05:48 PM
View Ranger's Photo Album
Casino Cash: $27171
NONE
  #7 (permalink)
Old 03-13-07, 05:58 PM
Casino Cash: $5797
Originally Posted by Ranger View Post
NONE
So they are BS... oh...
  #8 (permalink)
Old 03-13-07, 06:21 PM
Casino Cash: $27171
I consider most of them as snake oil and unnecessary.
  #9 (permalink)
Old 03-13-07, 07:15 PM
Raze's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 90 Eldo -SOLD-, 98 ETC -SOLD-, 86 XR4Ti Track Car, 07 Ranger
View Raze's Photo Album
Casino Cash: $5675
how bout doing a full tune up, plugs, wires, fuel filter, check your fuel pressure regulator...
  #10 (permalink)
Old 03-13-07, 08:21 PM
Casino Cash: $5797
Thanks Raze. Sounds excellent. I do have the new Air Filter, Fuel Filter and FPR though. I know for sure it'll be tuned up. I will def add the plugs to my list.
  #11 (permalink)
Old 03-13-07, 08:39 PM
Casino Cash: $27171
Be sure to stick with A/C Delco plugs & wires.
  #12 (permalink)
Old 03-13-07, 09:44 PM
Raze's Avatar
Casino Cash: $5675
amen to that ranger...
  #13 (permalink)
Old 03-14-07, 11:56 AM
Mountie's Avatar
Casino Cash: $997
Well....if we are including as many "check items" as possible, ,.......use soapy water & a clean razorblade to clean the windshield - then new wipers.
  #14 (permalink)
Old 03-14-07, 03:10 PM
SL1CK's Avatar
Cadillac(s): 1996 Cadillac Seville STS
View SL1CK's Photo Album
Casino Cash: $560
After you tune it up, have your engine detailed. Should be no more than 40-50$, make your engine look new.
  #15 (permalink)
Old 03-14-07, 04:23 PM
Casino Cash: $5797
Thanks!
I'll make it look new.
It is a little dusty... but was detailed and always is
Tags: , , ,
advice, and or or, clean, tips
attach your bluetooth cell phone to onstar
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
