•Repair torn and worn-out boots of suspension tie rod ends - without having to buy the entire and expensive tie rod!
•Adds durability surpassing most OEM rubber boots.
•Exclusive 5 point sealing action.
•Choose from four sizes* and Round or Octagon styles.
•Made of Energy's HYPER-FLEX™ performance polyurethane for added performance and durability.
At last it is possible to replace a damaged tie rod dust boot without having the expense of buying an entire new tie rod! (Typically when tie rods are worn, an entirely new tie rod end is need and the additional expense of a suspension alignment is required.)
These exclusively engineered Energy Suspension ® boots resist damage from rocks, sand, water, road salt, and oils better than many other O.E.M. rubber boots.
All boots have a 5 Point Sealing Action, which not only prevents loss of tie rod lubricant but also inhibits contamination (the major cause of rod wear)! Availalble in red or black color.
GIVE YOUR VEHICLE SUSPENSION ADDED DURABILITY!
Ball Joint Boots
•Repair torn and worn-out ball joint boots without having to buy the entire ball joint just to get the boot.
•Adds both durability and that custom look attention custom show car builders!
•For selected vehicle models only*.
Finally, someone has made a replacement ball joint dust boot! No more expense/cost worries when the boot wears-out or is damaged either from installation or from day to day use. They resist damage from rocks, road salt, sand and water better than many rubber boots. Sets includes two upper and two lower boots. Available in red or black color.
LASTS LONGER, SEALS BETTER & LOOKS GREAT FOR SHOW VEHICLES!
Be sure and get red, they go faster...
