Results 1 to 6 of 6
Thread: LT1 B/D PCM tune vs LT1 F/Y Tune
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    50
    7,531
    Something I have noticed, all the B/D cars have a 20 degree offset on the timing table, and the F/Y cars don't.
    I think I found out why.
    The Timing tables can go from 0 to 110 degrees. But there are some places in the timing table that GM goes negative in the B/D tune at a couple places in the timing table. The F/Y tune does not go negative.
    Simple!
    bigbluebrougham's Avatar
    bigbluebrougham is offline Cadillac Owners Fanatic
    Automobile(s): 1995 Cadillac Fleetwood Brougham
    Nov 2006
    South Dakota
    36
    118
    Re: LT1 B/D PCM tune vs LT1 F/Y Tune
    Any particular reason?? I am so new at all this, just wondering why they did that...
    BBB
    N0DIH's Avatar
    Aug 2004
    Rockford, IL
    50
    7,531
    Just what I said, they can push the timing below 0 degrees. The stock B/D has negative timing, the stock F/Y doesn't, so they don't need to.
  5. #4
    Nov 2006
    South Dakota
    36
    118
    I guess what I meant is why would a car go below zero in timing, moreover, is it good?? Must be since my car still runs good! I just don;t have the slightest clue what a timing table is. My old pickup I know you have initial and total timing, that I understand. Is this the same?
    BBB
  6. #5
    N0DIH's Avatar
    Aug 2004
    Rockford, IL
    50
    7,531
    They have it set to do it in odd conditions like super low vacuum and low rpm. Like engine start. If you get very high at that condition you can get starting pinging.
    My 454 sees 0 degrees timing factory at high load conditions. Even negative timing. There is initial timing in the PCM tune, but it is the closed throttle timing now, and the timing maps handle it all now. There isn't "advance" like in a distributor anymore...
  7. #6
    Nov 2006
    South Dakota
    36
    118
    Now I get it!!
    Thanks for the clarification!
    BBB
    P.S. As soon as my laptop is done in the shop, (friend is fixing it for free, for some reason he is slow on fixing it, can't complain, free fix!). I will let you know on the tuning part.
  • You may not post replies
