Which PCM used for 2006 STS 4.6L rearwheel ?
Results 1 to 6 of 6
Cadillac Powertrain Control Module (PCM) Tuning Discussion, Which PCM used for 2006 STS 4.6L rearwheel ? in Cadillac Engine Discussion; Any know which PCM is used for a 2006 STS with NA 4.6L (code A)engine and rear wheel drive, is ...
    Team ZR-1 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Aug 2006
    86
    is it a E67 PCM ?
    Thanks
    Apr 2011
    Tuning in Rock Hill SC
    48
    66
    Re: Which PCM used for 2006 STS 4.6L rearwheel ?
    We have 1 in stock, but it's not an E67
    2006 4.4L STS-V uses an E67
    Part Number: 12576523
    CADILLAC 2004-2006
    SRX 2004-2006
    STS 2005-2006
    XLR 2004-2006
    Aug 2006
    86
    This STS is a 2006 with 4.6L N/A, rear wheel drive and I was told depending on which engine, if having boost or front or rear wheel drive had different PCMs but which PCM does the NA 4.6L rear wheel use ?
    Thanks
    Apr 2011
    48
    66
    This is the E22 ECM used in 2004 to 2006 RWD Northstar's except the 2006 STS-V 4.4L
    This is the P07 PCM used in the 2004 & 2005 FWD Northstar ------ Note it is the same picture -- I will have N0dih update it
    This is the 2 side by side
    ---------- FWD ------------------------------------------------------------- RWD
    This is the E67 used in 2006+ FWD Northstar, the 2006 STS-V, and 2007+ RWD Northstar's
    Aug 2006
    86
    Damn then not good news as it looks like this STS would be using a E22 PCM since it is rear wheel and not a E67
    That leaves out using Tunercat or LS2edit for tuning, so what tuning tool would work ?
    Thanks
    Apr 2011
    48
    66
    Quote Originally Posted by Team ZR-1 View Post
    Thanks
    John says the E22 uses a non AVT supported CPU
  9. Remove Advertisements
