PCM question
Results 1 to 5 of 5
Cadillac Powertrain Control Module (PCM) Tuning Discussion, PCM question in Cadillac Engine Discussion; What is the difference between the cadillac / aurora pcm's by year? I know the Cadillac pcm will control the ...
    motohead_1 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2008
    33
    12
    PCM question
    I know the Cadillac pcm will control the 4.0 and vice versa.
    Will the different years interchange? example can I use a 2002 computer in my 1996 or 97 if I were to use an engine from those years and will it even connect to the existing harness?
    Just curious I have access to a newer engine and computer just checking to see what my options are when my motor calls it quits...
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    50
    7,531
    Re: PCM question
    Take a look at car-part.com and see what PN's they list, probably same. Also shows year to year interchange, just write down what years you see from part to part. Takes a little study, but often very revealing.
    Nov 2008
    33
    12
    Re: PCM question
    I guess what I was asking is will the newer pcm work with some of the older electronics like the bcm, the dic and the radio and so on. I know it would take tons of re-wiring but that is no problem for me.
    N0DIH's Avatar
    Aug 2004
    Rockford, IL
    50
    7,531
    Re: PCM question
    I don't know if anyone has ever dug to find out.
    GM uses a bus architecture and sends many commands to things like DIC and radio and such (depending on year) as a Class2 or CAN bus command. So the answer is grey. Will the PCM send it? don't know, if it isn't designed to chatter with a Cadillac device that isn't on a BOP, then likely no. But could it? Very possibly.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,274
    Re: PCM question
    One thing certain between 2000 and earlier is the two different ignition systems. I'll bet a 2002 PCM will not drive a 96-97 ICM waste spark system. For starters the CKP's (CranKshaft Position sensor) and crank reluctor wheels are very different.
  8. Remove Advertisements
