98 Eldo pcm into a 97 STS
Results 1 to 5 of 5
Cadillac Powertrain Control Module (PCM) Tuning Discussion, 98 Eldo pcm into a 97 STS in Cadillac Engine Discussion; I have a 97 STS that is failing emissions due to a not ready response. I ran the car for ...
    JoeMack is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Apr 2007
    Question98 Eldo pcm into a 97 STS
    I have a 97 STS that is failing emissions due to a not ready response. I ran the car for almost 60 days with many cycles and conditions and can't get the computer into a ready state. Mass won't inspect with a tail pipe test on any OBD II car and I can no longer drive the car on the road. Even if I have the computer looked at by a authorized inspection repair center I will no longer be able to drive it to attempt another reset.
    My 98 Eldo blew a HG at 160,000 and I kept the pcm, many sensors and the resistor that I had spliced into the wires that check the key chip resistance. Does anyone know if I can put this pcm into the 97 STS? I do realize that this would most likely cause the radio to lock-out. Honestly, I just want to get this thing a sticker for another year. In order to reset the pcm to ready, assuming this will work, I will have to have my wife sell me the car, this will allow me to legally drive it on the road for 7 days before I will need to inspect it again.
    -Thx
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    Re: 98 Eldo pcm into a 97 STS
    no
    the PCM must be calibrated for your car
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    48
    2,755
    Quote Originally Posted by JoeMack View Post
    -Thx
    I need your VIN
    Apr 2007
    Guys thanks for the replies. AJxtcman I enjoyed reading your thread on the root cause of head gasket leaks. It appears for a few years that Cadillac had a metallurgy problem as well as load fatigue from a lack of thread engagement. I'm not sure which condition I had in my Eldo, the car ran and looked impeccable but had too many miles on it to warrant a tear down. I do know that the leak was only into the #1 cylinder.
    I have since read a response you gave someone else about the Y and 9 engines. I realize there may be too may differences in the PCM. If so can the PCM be reprogrammed by Caddy?
    I was wondering if the PCM is never ready due to a poor or broken contact in the wiring harness.
    Here are the VIN's.
    98 Eldo. ETC: 1G6EL12Y1WU61XXXX
    97 STS: 1G6KY5296VU82XXXX
    -thx
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    48
    2,755
    Here are the VIN's.
    -thx
    I need the last 8 of the 97.
    I will run a GM VIS and look at the emmision options.
  8. Remove Advertisements
