Limitter adjustment/removal - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Cadillac Powertrain Control Module (PCM) Tuning Discussion, Limitter adjustment/removal in Cadillac Engine Discussion; Originally Posted by Hogg Guys have been using Tech 2 to load PCM's for years, before the times of TC2(specifically ...
  1. #16
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    48
    2,755
    Re: Limitter adjustment/removal
    Quote Originally Posted by Hogg View Post
    Guys have been using Tech 2 to load PCM's for years, before the times of TC2(specifically Winflash), EFILive, HPTuners LS1 EDit etc.
    A Tech 2 loaded file can 100% be pulled with any tuning suite. I have done so personally.
    peace
    Hog
    I haven't done a 8 segment file. You have to have all 8 segment broken apart to use the tech 2 when loading a custom tune. All single segment files are easy
    Do you know how to load a custome tune with the Tech II?
  2. #17
    Hogg is offline Cadillac Owners Member
    Automobile(s): Cadillac 1998 STS
    Nov 2008
    Woodstock Canada
    98
    I dont have any experience with single segment files, only 8 segment files, like are in the blackbox PCM's(96-00) Vortec 4.3/305/350/454 trucks.
    I have only pulled 8 segment calibrations that has been loaded using TECH2.
    peace
    Hog
  3. #18
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    48
    2,755
    When the calibration is downloaded from GM it is stored on your PC in a location. Each segment is stored as a special zip file with the segment # added to the calibration number. The special zipped file is transferred through or to Tech II or MDI and it must be zipped.
    If you use TC and tune a single segment file then zip it, them make sure that the file number is the same and then replace the existing file with the tuned file TIS will load it through the Tech II.
    If you monitor the "folder" that the zip files are stored in while doing a TIS flash and you see the cal pop up again you did something wrong. If nothing changes in the folder you did it the correct way.
    BTW I left out some information. little things.
