Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > Cadillac Powertrain Control Module (PCM) Tuning
Cadillac Powertrain Control Module (PCM) Tuning Ask questions - Get answers in our section for discussions regarding Cadillac PCM tuning for engines such as the LT1, LS6, L92, LQ9, LQ4, L03 (TBI 305), L05 (TBI 350) and more...
Cadillac Forums: Northstar Tuning
  #241 (permalink)
Old 05-11-07, 08:06 PM
Cadillac(s): Member of Air Fuel Tuning (Cadillac Division)
View AJxtcman's Photo Album
Casino Cash: $13342
Re: Northstar Tuning
Originally Posted by ejguillot View Post
I'm also interested in a reprogrammed PCM, and am watching this discussion with great interest. What I would be looking for:
Speed limiter delete
Corrected shift points (My car shifts at 6300 and fuel cut off is at 6500, shouldn't it be 6500/6700 for a 2000 STS, 8/99 build date, VIN # 1G6KY5492YU144325)
Eliminate any torque management, also maximum shift speed/line pressure when shifter is at 2 or 1
Most aggressive factory fuel/timimg curves available (My N* is tuned for regular, I would accept having to run midgrade/premium)
Any particular PCM I would need to send you, and is used OK (can I pick one up from eBay or a junkyard?)
Edwin
do you want to run cats?
Any 2000 to 2003 Northstar PCM is good
I have been paying $20 to $25
  #242 (permalink)
Old 05-11-07, 10:33 PM
Casino Cash: $13342
I pushed the envolope way to far on my little rocket. It does not sound good. I think I bounced a valve. Too many RPM's. ouch
  #243 (permalink)
Old 05-11-07, 11:52 PM
View eldorado1's Photo Album
Casino Cash: $5065
Were you running a vin 9 calibration on a vin y? That would allow you to pass 500 rpms above the rev limiter.
  #244 (permalink)
Old 05-12-07, 01:50 AM
CadillacSTS2003's Avatar
Zeeee-yaaaa
Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC
View CadillacSTS2003's Photo Album
Casino Cash: $12230
Im still waiting on this pcm?
whats the deal?
  #245 (permalink)
Old 05-12-07, 03:12 AM
Cadillac(s): 1997 Cadillac ETC
View OffThaHorseCEO's Photo Album
Casino Cash: $2575
somethin smells, and i think i hear cowbells
  #246 (permalink)
Old 05-12-07, 09:18 AM
Zeeee-yaaaa
Casino Cash: $12230
idk what to believe
the proof seems solid
however he keeps stalling...
  #247 (permalink)
Old 05-12-07, 10:05 AM
Casino Cash: $13342
PM me your Email address and I will show you a portion of the software I use.
The engine had 4557 miles on it when I pulled it out for a bad casting. I patched welded it. The coolant in between the layers was contaminating the weld. I was using a alloy product from my local supplier. The small leak soon spread to a 6" long Fish Scale like area. Ever time I thought I had it good some coolant residue would come up. I thought I had it good and so I installed it in the car. I was being rushed. The f****** idiot across from me wanted the engine support that I had the powertrain unit on. I installed the engine to give him the support table and had never pressure tested the block. It leaked at the head gasket. I dropped the powertrain out Pulled the head off and found that the layers of casting split all the way to the deck surface. I head back to the welding supplier to get some type of cleaner or flux. He called the manufacturer and they told him I should not use this product on this alloy block. I dig all my wire feed crap out to weld aluminum and get a some old alloy wire I had. I cut about half the wire off the roll and grind all the crap off the block. Reinstalled the head and pressure test it . Good to go. I had never driven the car off the lot with the coolant leak. I changed the oil and had everything taped off when I was grinding and welding. I had just ran the engine a couple of time with the leak.
After I Reinstalled the engine It sounded like it may have a misfire. I ran it to the Exhaust shop to have two little mufflers put on it so I could hear the car run. I had a Misfire in #7. Pulled the plug, then swapped it with #5, checked the wires, swapped out the coil assembly, and checked the injector. I found nothing, but when it missed I could hear an exhaust change. The miss slowly went away. If I would drive the car it would come and go. I cleaned the injectors twice. The more I drove it the less it happened. If it did miss it would stop if I let it idle. If the Torque Management kicked in it would misfire about 80% of the time immediately following that and I would let it idle about 15 second and it would be fine. Sound like a poor connection . If I make a sharp turn or U turn it would misfire about the same. I would just let it idle and it would clear out.
Last night I was collecting more data on the program and about 100 MPH it shift back into 2nd for 1 second I let off the gas and then replanted my foot. ran it to 136 MPH and backed it down I over shot the first drive way so I drove down to the second drive way. I was at a cruise of about 35MPH. I did my U turn and it started to misfire.
This is a 96 to 99 replacement engine. I have been wondering what could be the cause. Loose wire in my custom built harness? How about oil in the intake? The oil build up in the intake is cause by two thing first is high RPM ( I have that) the second is a baffle problem in the rear valve cover. The valve cover only has 5000 miles on it. You have to have both to get that much oil in the intake that it would slosh to one side and then misfire.
This time the misfire did not clear up and it started to knock like a spun bearing or something in a cylinder. I limped it back home about 1 mile and it did not get better.
I think it stuck a valve open and if I had to guess it is #7 cylinder. I do not understand why a U turn would cause a valve to stick.
I pulled the power to the coil and cranked it this morning and it has a cylinder with low compression.
I am headed back to the dealership this morning to check it out.
In the snapshot I got it showed the PCM shifting 1st, ...... 2nd, ........ 3rd, ...2nd, 3rd............
I had taken someone for a ride yesterday just before 5pm. Nice customer. I had mad a comment that I thought I heard some type of exhaust note difference from side to side, but I did not have a miss and it was very smooth.
I am selling it at the end of the month and was realy pushing that deadline.
  #248 (permalink)
Old 05-12-07, 10:24 AM
Casino Cash: $13342
eldorado1
The base program was an VIN Y
If you tune a LT1 The base program is an LT1. If you program an LS1 you may start with an LS1. If you are tuning your LS1 PCM you are using a LS1 base program. If you have an LS2 the program is for a 6.0L not a 5.7L and you would start with a LS2 program and adjust from that base program.
If you wanted to waste time you could take a LS1 and rework it to a LS2 and then rework it to your preferences.
Can everyone follow me on this.
I am not just loading an OEM calibration in a PCM and then charging you $1000.
I am not reloading a different VIN into a PCM and sending it out.
I am not charging $1000 to load a different VIN
I am not Charging $1000.
If set the code for w rated tires and that is it. We would be talking a small donation.
The more time and efford the more I would request.
  #249 (permalink)
Old 05-12-07, 10:36 AM
Zeeee-yaaaa
Casino Cash: $12230
ok well as soon as you find a pcm cheap which works let me know and ill pay for the pcm you program it send it out and if it works as i said ill pay you your fee. thats been my offer this whole time. but were still waiting the entire forum is and as i said not to be rude but the more and more and the constant delays makes it seem like your less than legit.
  #250 (permalink)
Old 05-12-07, 12:06 PM
Casino Cash: $2575
man ive kept quiet pretty much this whole time (i think) but i gotta say something. this guy is rambling, he makes no sense. ok so he knows where to get software, he knows how to load software. but it seems to me that someone questions him and he replies with something like this
this to me is rambling and proves nothing. i hope noone pays him in advance until we see lots and lots of proof. i can see this being one of those cases where a guy builds trust then runs off with a bunch of peoples money (think approximately 300 dollars and assume about 15 guys pay in thats 4500 dollars, imagine in he charges 4 or 5 hundred and more guys fall for it)
  #251 (permalink)
Old 05-12-07, 01:00 PM
Casino Cash: $13342
Some fellow forum guy's state that I am just reloading a different VIN.
THAT IS NOT THE CASE!!!!
That is my point!
I am not using German VIN's in the PCM.
I have Loaded many VIN's into the program and compared them!
I have this SLS right now. I will run it to 150MPH on the hoist and then show you.
  #252 (permalink)
Old 05-12-07, 01:53 PM
Casino Cash: $13342
This is the same 02 SLS
  #253 (permalink)
Old 05-12-07, 03:39 PM
Casino Cash: $13342
I broke the top off #7 piston!
Timing?
  #254 (permalink)
Old 05-12-07, 05:23 PM
submariner409's Avatar
Casino Cash: $20669
Welcome to the world of tuning, building, and racing. That's not your last burnt/cracked piston on the road to reliable performance. I'm not knocking your efforts to outguess GM - but there are more engines to go before you can market a performance increase with reasonable assurance someone else's engine won't blow. Is there a knock sensor code? It would be interesting to know the engine operating conditions when the piston let go......probably too much advance with too little octane.
  #255 (permalink)
Old 05-13-07, 05:46 PM
Casino Cash: $13342
John did you get a chance to check out your new program?
If it is not right let me know.
Give me a call if The MIL comes on.
Tags:
northstar, tuning
Censor is OFF
