Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > Cadillac Powertrain Control Module (PCM) Tuning
Cadillac Powertrain Control Module (PCM) Tuning Ask questions - Get answers in our section for discussions regarding Cadillac PCM tuning for engines such as the LT1, LS6, L92, LQ9, LQ4, L03 (TBI 305), L05 (TBI 350) and more...
Cadillac Forums: Northstar Tuning
  #211 (permalink)
Old 05-10-07, 12:51 PM
Cadillac(s): Member of Air Fuel Tuning (Cadillac Division)
View AJxtcman's Photo Album
Casino Cash: $13342
Re: Northstar Tuning
[quote=mike0580a;1078561]I so want to see this done, but it's not a simple process.
QUOTE]
Read this thread FROM THE START.
  #212 (permalink)
Old 05-10-07, 01:09 PM
View eldorado1's Photo Album
Casino Cash: $5065
Look here.
http://www.hptuners.com/forum/showthread.php?t=11363
This isn't "tuning" as HP tuners would define it.
This is reprogramming a factory computer with another factory calibration that would not have been loaded unless your car was being exported to Germany (for instance). If you're on the autobahn you don't want a speed limiter kicking in at 110mph
TUNING is changing the AFR, spark timing, shift points... a lot of things that won't happen here.
  #213 (permalink)
Old 05-10-07, 01:20 PM
Cadillac(s): 99 SLS
View mike0580a's Photo Album
Casino Cash: $250
[quote=AJxtcman;1078579]
I did. I want the finished product (just like everyone else ). I'm in your cheering section. I'm about $700 in to HP Tuners right now and they outright swore off the N*. I want the GUI and all.
Most GM engines have rev limiters as well as speed limiters. You may be hitting peak RPM vice peak allowed speed. TC (usually) works on revs, not speed. Hit a set rev limit and spark is retarded.
Here's a vin for you, 99 SLS.
1G6KS54Y8XU929360
Mike
  #214 (permalink)
Old 05-10-07, 02:31 PM
Casino Cash: $13342
Now the problem is Code deffinitions. THAT IS WHAT I AM WORKING ON. You will not have a different VIN or You may get a different VIN. This is an example
Identifying Duramax Diesel Aftermarket Power-Up Devices TSB #06-06-01-007
Installed Power-Up Kit
Aftermarket power-up kits have become a very popular add on for performance-minded customers. These devices can add horsepower and torque and can add additional stress to the engine. These aftermarket calibrations take the Duramax™ powertrain outside of its design torque and horsepower rating. They do this by altering air/fuel ratios and injector timing, resulting in excessive cylinder pressure and temperature. When these calibrated parameters are altered, it will upset the design balance and can lead to a reduction of engine life expectancy. Generally, in inspection of Duramax™ engine failure due to power-up failures, two or more cylinders will be affected.
Once installed, the calibration may mask itself with the factory original calibration ID and may remain the same.
• A Tech 2® will not positively enable you to identify the use of a power up device.
• Some companies that offer power-up devices claim increases of 150 or more horsepower and 300 or more lb/ft pounds of torque.
• A vehicle that is used to the power-up device potential 100% of the time will see earlier engine wear and breakdown.
• A vehicle that takes advantage of additional power, but on a less frequent basis, may not see premature engine wear and breakdown until later in the engine's life.
• A vehicle not pushed to its limits of the power-up device often may not encounter premature wear and breakdown until after the engine is out of warranty
If I look at several Calibrations in this software for long enough I will see a blur. Just joking I see differences between Y and 9 Vin's, S rated tire, H rated tires, W rated tire, AIR with or without, Dual AIR pumps, with or without Catalyst. You can follow me know?
  #215 (permalink)
Old 05-10-07, 02:36 PM
Casino Cash: $13342
The sad thing is that Northstar Protocols are all by themselve. 4.0L are even different.
  #216 (permalink)
Old 05-10-07, 03:20 PM
Casino Cash: $5065
A diesel is not a gasoline engine. If you think you can get 150 "extra" horsepower out of a northstar, I've got some beachfront realestate to sell you in Nevada. (I'll sell it cheap, because I've got connections.)
  #217 (permalink)
Old 05-10-07, 04:27 PM
codewize's Avatar
Cadillac Owners Master
Cadillac(s): 1989 STS / 2001 DTS / 2002 DTS
View codewize's Photo Album
Casino Cash: $14455
I don't really care if we call it tuning, tweaking, breaking, hacking or what have you. If it works and we gain something without compromising the car, we have won the battle.
I lost track of all this. Where do we stand. The last I knew we were waiting for another PCM to show up and would be shipped to CadillacETC1997.
EDIT : OK I'm caught up now
Ownership:
89 STS (1 of 1893) - FOR SALE
02 Blue Onyx DTS
01 DTS:
Custom installed Volant CAI
Custom PCM
Body color engine components
Cruiser Alloy wheels
EBC brakes
Eibach springs
Corsa exhaust
Sportwing Spoiler
Semi-custom interior
Custom quad Hi-Beams
Future Plans: More interior work.
Memberships:
National and regional Cadillac & LaSalle Club
Proud Volunteer - Northstar Tuning Project
  #218 (permalink)
Old 05-10-07, 04:39 PM
Casino Cash: $13342
Yes I need a PCM
  #219 (permalink)
Old 05-10-07, 04:41 PM
Casino Cash: $13342
This is from a GM TSB. The point I was trying to make is that the STOCK VIN and CAL ID can stay the same! This is used to MASK the custom Calibration!
  #220 (permalink)
Old 05-10-07, 04:44 PM
Casino Cash: $13342
Identifying Duramax Diesel Aftermarket Power-Up Devices TSB #06-06-01-007 [/size]
SEE The highlight
  #221 (permalink)
Old 05-10-07, 05:20 PM
AlBundy's Avatar
Cadillac(s): 1996 Eldorado Sport Coupe
View AlBundy's Photo Album
Casino Cash: $226735
AJxtcman, keep up the good work. I'm with you. If the other tuner guys read this thread they might get some kind of vibe that there's a market for the N*. As you can see everyone is excited so keep that in mind when reading comments.
  #222 (permalink)
Old 05-10-07, 06:25 PM
Casino Cash: $5065
Make friends with a cadillac tech and tell them to reprogram your vehicle with a german export calibration. Voila, no speed limiter.
I wouldn't call that "winning" because you still can't tune for cams, or exhaust, or custom intake manifolds, etc... See what I mean? It's not tuning if a dealership can do it, and it uses factory programming. HP Tuners, etc modifies the factory program to change the air fuel ratio, spark timing, revlimiter, etc etc.
  #223 (permalink)
Old 05-10-07, 06:28 PM
Casino Cash: $5065
your point must have flown completely over my head. I still don't understand the significance. Are you saying there's some 96 STS with 400hp from a performance tune out there that reads as a stock calibration?
  #224 (permalink)
Old 05-10-07, 09:03 PM
Casino Cash: $13342
YOU ARE COMPLETLY INCORRECT!!!!!!!!!
First: some German cars have V rated tire and will not go 140 MPH!!!!
Second: What the f*** is the only Mechanical difference between the 9 and Y!
............ THE CAMS. That would be tuning for cams from the factory!
If I can see the difference between the Y and 9 Then why can't I go Further?
I do not know of one Dealership that has the Program that I am using!!!!!!!!!!!
Now for the Duramax.
I see a lot of Duramax's with altered programs or add on programmers.
After a few tuner customers blew motors the aftermarket Guy's got very smart. In the past even back in the 80's the aftermarket programmers proms or programs could be identified very easily. If your car broke. then manufacturer could say they would not cover the repair. A Duramax installed may cost 10k out of pocket!
ARE YOU FOLLOWING ME
Now the aftermarket programing companies are reusing the factory Calibration ID's and VIN's. This is to trick the dealers or the Manufactures so they will have to repair the damaged part.
DID YOU FOLLOW THAT
THIS HAS NOTHING TO DO WITH HORSEPOWER.
THIS STATEMENT AND THE DURAMAX INFORMATION I HAD LISTED WAS JUST INFORMATION ABOUT CAL ID'S AND VIN'S USED TO KEEP YOUR F****** WARANTY!!!!!!!!!
  #225 (permalink)
Old 05-10-07, 09:32 PM
Casino Cash: $13342
2003 VIN 9 W rated tires ALL FOR KY CARS
I CAN NOT LIST THE VIN's
Country.........Cal ID's
GERMANY .............12585514
USA........12585503
JAPANESE..........................12585515
KOREA.................12585514
TAIWAN.........................................125 85510
GERMANY ............12585514
USA.......12585503
USA.......12585503
USA.......12585503
USA.......12585503
USA.......12585503
USA.......12585503
USA.......12585503
USA.......12585503
USA.......12585554 This would be VIN 1G6KY54953U227322
2000 VIN Y QLD (235/60R17/X WS1 R/PE ST TL ALS)
CAL ID's
12585589
12585589
12585589
2000 VIN 9 QDC - TIRES-GOODYEAR EAGLE LS P235/60ZR16
Country ..... CAL ID's
USA 12585569
2000 KY VIN Y QDC - TIRES - P235/60ZR-16"ALL SEASON PERFORMANCE TIRES
Quebec 12585575
99 KY VIN 9
Tires .............. Cal ID's
QDC 9388186
QDC 9388186
QDC 9388186
QDC 9388186
QDC 9388186
QDO 9364466
QDC 9388186
QDC 9388186
QDC 9388186
QDO 9364466
QDC 9388186
QDC 9388186
QDC 9388186
QDC 9388186
QDC 9388186
QDC 9388186
QDC 9388186
99 KS VIN 9
Tires......... Cal Id's
1G6KS54Y8XU------ QDO 9364456
Yes this is a 150MPH VIN Y
Now I over lay this ontop of a V rated tire and then I know thw code for the tire.
I can also take this and over lay it so I can see the differences in the cam programs between a VIN 9 and Y.
Quick questions
Who built the program that is used in the LS1 packages?
GM or did GM outsource it?
The aftermarket Programs just alter it correct?
They don't start from scratch correct?
CAN YOU FOLLOW ME.
I have so many more ID's just list and list
Tags:
northstar, tuning
Censor is OFF
