Go Back   Cadillac Owners Group > General Discussion > The Cadillac Forums Lounge / Member Introductions > The Cadillac Owners Garage
The Cadillac Owners Garage Pictures and explanations of our member's vehicles.
Cadillac Forums: My 91 SDV
Old 01-27-09, 10:52 AM
Ghost C's Avatar
Cadillac(s): '91 Sedan DeVille Silhouette Special
View Ghost C's Photo Album
Casino Cash: $3055
My 91 SDV
The Cadillac everyone loves to hate, my 91 DeVille, I'll be updating it from time to time with the newest mods and specs.
Evoluzione Engineering CAI
Evoluzione Engineering Ground Wire Kit
8deg Timing Advance
2.75" Exhust w/ OTTO Racing Remus Style Muffler
Oil Catch Can
Power Steering Fluid Heat Exchanger
Radiator End Tank Engine Oil Cooler
Radiator End Tank Transmission Fluid Cooler
Front-Mounted Transmission Fluid Cooler
482lb Weight Reduction (3,603lbs stock)
Evoluzione Engineering Rear Strut Brace
Evoluzione Engineering Front Lower Tie Bar
Evoluzione Engineering Engine Brace Kit
Evoluzione Engineering Trunk Triangle Brace
Energy Suspension Swaybar End Links
Energy Suspension Ball Joint Boots
Energy Suspension Tie Rod Boots
(OBLIGATORY PLUG FOR MY SPONSOR ENERGY SUSPENSION)
Afco 450lb/in coilovers (F) (Waiting on new dampers to go in)
Vogtland 620lb/in springs (R) (Waiting on new dampers to go in)
ABS Delete
SBS Pro-Touring Ceramic Pads (F)
Raybestos Rotors (F)
Jeg's Adjustable Proportioning Valve
Full Metallic Shoes (R)
Enkei EUM5 16x7 (F)
Enkei EUM5 16x7 (R)
Fuzion HRi 215/60/16 (F)
Fuzion HRi 215/60/16 (R)
Evoluzione Engineering Blackout Front End
Custom Painted Brake Calipers
Evoluzione Engineering Interior Blackout Kit
Evoluzione Engineering Carbon Fiber Shift Knob
Dry Chemical Fire Extinguisher
Narrowband A/F Ratio Gauge
Mobil 1 Full Synthetic 10w30 Engine Oil
Mobil 1 Full Synthetic Dexron III Transmission Fluid
Valvoline Full Synthetic 500deg Brake Fluid
Valvoline Full Synthetic Power Steering Fluid
Planned Mods -
5 Speed Manual Transmission Swap
Port & Polish Work
Racing Seats
Racing Steering Wheel w/ Quick Release Hub
Weight reduction is key.
Flat black to cover up chrome is even more key.
Envy my beefy rotors. And my bushings p0rn. Big shout out to ES.
I adjust my brake proportioning often, simply 'cause I can.
  #2 (permalink)
Old 06-09-09, 05:55 PM
Ghost C's Avatar
Casino Cash: $3055
Re: My 91 SDV
Nothing exceeds like excess...
To monitor the function of the ram air...
The gAyPC narrowband was free, so why not put it in? Screw it.
Stewart-Warner Turbopac, measures vacuum and boost in in/hg, which means it will read to just under 5psi...
Perfect for something that should only create 1-2psi max
sdv
Censor is OFF
