View Full Version : Cadillac Big Block Engine Assembly Guide
Lord Cadillac
02-19-07, 11:13 AM
Click here (PDF) (http://www.caddilacowners.com/pdf/cadillac.pdf) - 4.41mb
wallaby11966
11-28-07, 03:20 PM
it says pdf file is damaged and can not be repaired, first couple of times i tried, it down loaded about 2.9 of the 4.4 , if you can can you send it to me in an email to wallaby11966@aol.com thank you
Boombotz
11-28-07, 10:38 PM
The link worked for me.
wallaby11966
11-29-07, 01:59 PM
my bad i finnally got it. problem must of been with me or my computer .
wallaby11966
11-29-07, 02:03 PM
i have a 500 cad motor with all new parts that im going to put in a car for my dad . ive built a few motors in my 41 years but mostly small blk chevy , the basics are the same but im afraid i will leave some thing out or do someting wrong . the motor is a 75 or76 ive got the pdf file , but it goes from 68-73. does any one out there have a video of some one building a 500 step by step.
steelybill
04-02-09, 11:37 PM
I built up a '76 500 OK. Like you, I've built a bunch of Chev SB engines. I think the file for the '73 should work OK for you. It's a straight-forward engine to work on. Timing the cam is different than a Chevy, but using the marks on the sprockets will get you there. Number 1 cyl isn't at firing- top-center like a Chevy when the timing marks are lined up.
steelybill
07-18-09, 12:03 PM
For folks doing a re-build on a 472/500, there is a stainless steel front plate available from www.cad500parts.com (Flashcraft) The original front sheet metal plate is often rusted/pitted and prone to leaks. The water pump is mounted there etc. Last time I looked, the new plate is $125.
BILL
