View Full Version : moisture inside headlight housing, how fix?
andrewdeville03
02-15-07, 03:42 PM
Noticed that the passenger side headlight housing has a lot of moisture droplets on the inside of the lens. 2003 Deville. I'll post a pic tomorrow morning. Thanks
xxpinballxx
02-15-07, 04:16 PM
well its cause ther eis air amnd moisture getting in there...obviously a leak in the seal...take the lamp out heat up the seal and pry apart....clean edges and make sure there is absolutely no adhesive left then reseal.....
JimD
02-15-07, 07:20 PM
Or, the bulb socket gasket is messed up.
andrewdeville03
02-16-07, 07:31 AM
I like Jimd's idea, its sounds like an easy fix, hehe
Ranger
02-18-07, 10:50 PM
Most likely there is a bad lens seal. Clear silicone caulk works wonders.
