: coolant levels
theloanman219
02-08-07, 03:44 PM
Recently I have had a check coolant code on my nav. Is this common. I know some people here have not had good luck with radiators.
svassh
02-08-07, 03:46 PM
I had it on mine a few weeks after I bought it and was worried about the radiator. It hasn't happened since with 4K miles. Top it off and see what happens. There is a radiator TSB on the Faq so it is common.
Holmes815
02-08-07, 03:58 PM
It happened to me too recently, I think it's just due to the cold (hopefully) like the power steering noise/fluid issues!!
--James
Rockafella
02-08-07, 04:06 PM
Me Four. I topped it off two weeks ago.
SilverBullet
02-08-07, 05:18 PM
mine was coming on as well. I had to have the radiator replaced. Fixed it. Common issue.
theloanman219
02-08-07, 05:27 PM
im going to call the dealer in the morning. They are great!
G--
02-08-07, 09:07 PM
Happened to me last month, code came up twice. Took it to the dealer, replaced the radiator under warranty. Report indicated a tiny leak and radiator was replaced.
As a side note, I took it back 2 days later when the code came back on, turns out they forgot to "burp" the system (I guess they didn't drive it afterward), they added a little fluid and no problems since.
I will tell you that before the initial code came on, there was the very faint odor of antifreeze I would barely get every so often, but only if the "wind was right" when I got out of the car. Per the info here, I suspected a small radiator leak and sure enough that was exactly what it was.
mocts
02-08-07, 09:12 PM
does this happen on the regular cts to or is this problem mainly associated with the v
1QUICKV
02-08-07, 09:23 PM
its because of the cold and high RPM'S That was the tsb says. (RPMS)
