Old Fleetwood
02-07-07, 10:56 PM
How often should these be replaced?
We're talking about an LT-1 Mine happens to be a 95 in my FWB.
On many Mopars, these should be replaced around 60k miles, when the belt is replaced although nothing in the replacement schedule says to change them out with the belt.
The Allpar site, however, notes that the pulleys and idlers usually fail at around 80k or 90k. That's 20 or 30k after the belt change, unless you're really lucky, so I have to wonder about the belt in my FWB since something makes an intermittent noise at startup.
The noise stops after about 5 seconds when first starting in the morning and will not show up again for the rest of the day.
Since the overnight temp is near zero, however, the underhood noise is one helluva squawk now for about 10 seconds. That's actually less of a worry since cold weather - around 5 above zero - seems to make everything cranky. And as before, everything quiets down after that 10 seconds of squawling.
BTW - the serpentine belt has been checked and pronounced perfect by not only me but the dealer and the mechanic I trust, locally.
