View Full Version : Headlamp Washers
john d
02-06-07, 09:02 PM
Has anyone used the headlamp washers and if so how well do they work?
RunningOnEMT
02-06-07, 09:08 PM
if they are anything like the ones on my CTS-V they work whenever the headlights are on and you wash the windshield... i know mine work QUITE well...
GMJim
02-07-07, 05:23 AM
They work awesome. As posted, the headlamps must be on to get the headlamps washed. If you are low on fluid, just the windshield will be washed.
I love em!!!!!!!!!!!!!!
TSS
02-07-07, 07:12 AM
Right - they automatically come on when the lights are on and you hit the windshield wash switch.
They do work well, but personally, I hate them. My SRX is white. The fluid is green or blue. It splatters all over the front end and looks like I got hit by a childs watercolor set. I have looked for clear or even yellow fluid with no luck. My solution is that if the car is realatively clean, but I need to wash the windsheild, I override the auto headlights. Once they are off, problem solved. After the windshied is washed, I then turn them back on auto.
Futher, I don't like the way they look. SRXs without them look better to me.
Also, don't use them in your garage. In mine, I park very close to a side wall and the fluid over-sprays onto the wall a little bit. YES, they are aimed correctly - they are just such a high pressure that there is splattering.
DOES ANYBODY KNOW A QUICK AND EASY WAY TO PERMANENTLY DISABLE THEM?
RunningOnEMT
02-07-07, 07:19 AM
advance auto sells the PIAA windshield washer fluid ... its neon orange, and they even have yellow
donjumpsuit
02-07-07, 10:04 AM
Their is definitely a servo that operates them, which means they run on electricity. Short of clipping any wires that run to them, you could pull a fuse.
n7don_srx
02-07-07, 11:44 AM
TTS
"DOES ANYBODY KNOW A QUICK AND EASY WAY TO PERMANENTLY DISABLE THEM?"
The lamp washer appears to have it's own pump. Might be a quick fix to just unplug it. Risk is it might set a DTC but should be benign and reset if you plugged it back in.
TSS
02-07-07, 11:54 AM
I may try the yellow fluid suggestion first because, as I indicated before ranting, they do work well when you want them or don't care about the splatter because the car is already dirty.
Thanks for all the suggestions though!
n7don_srx
02-07-07, 12:03 PM
Good Plan A.... after reading some more, the fender well has to be removed to get to it. I can't even see it from the top side.
Northern SRX
02-07-07, 07:05 PM
As stated above, the headlamp washers work extremely well - so well, in fact, that the Xenons appear sufficiently brighter that oncoming cars flash their highbeams even more frequently in sloppy weather.
In my first winter with the SRX, I had problems with the nozzles not retracting - both were replaced and lubricated and I have had no such problems that past 2 winters. :yup:
As for the fluid colour debate, I recently switched to a windshield fluid manufactured by Rain-X and it is decidedly yellow in colour as is rated to -40F.
Smokin' SRX
02-14-07, 01:28 PM
So you're the guy blinding me! :thepan:
:) I adjusted mine easily through the holes, above the headlites (visable with hood up only!) and a long allen key! Took minutes and used my driveway & garage door. Any flat surface and wall, will do! Looks even better coming down the road now!
mjk
02-14-07, 02:21 PM
Are headlamp washers standard or was it an option (04 v6)??
Northern SRX
02-15-07, 01:59 AM
Hey, sorry about that... ;)
So, when you adjusted them, did you adjust them upward??? :rolleyes:
When I had our garage floor poured, it was made as flat as can be - so I could easily adjust headlamps. When I first started getting people flashing their highbeams at me, I must have checked the headlight aiming 3 or 4 times and they never needed an adjustment! Eventually, I realized that the flashing only occured in "dirty" conditions when others' eyes were most likely not accustomed to seeing clean Xenons coming at them. Not much I can do about that one...
TSS
02-15-07, 07:10 AM
For 2006, they came standard w/ the V8 or avail on the v6 w/ the luxury package (I think the package included headlight washers, 18" rims, more interior wood, etc).
Not sure about details for 2004. I know they were definitely not standard equip on a v6 in 2004 though.
