: '05 and earlier vs. '06 and newer Change in rear suspension geometry and ls-6 to LS-2
Washin
02-03-07, 04:53 PM
My understanding is that there were some kind of suspension changes made to the 2006 V's to help address the excessive wheel hop. Is this true? If so what did they change? Also what are the pros and cons to the newer LS-2 motor vs. the LS-6.:confused: Thanks
The Tony Show
02-03-07, 05:07 PM
They inserted hard bushings above and below the cradle bushings as factory equipment. The same bushings can be added to an earlier CTS-V under warranty.
As far as the motors, the LS2 is a little punchier down low, while the LS6 has better top end. Both run 0-60 and the 1/4 mile in about the same time.
thatv07
02-03-07, 05:13 PM
anyone with an 07 V with rear diff problems?
rand49er
02-04-07, 07:07 AM
anyone with an 07 V with rear diff problems?Won't be long now ...:food-snacking:
gcoan
02-04-07, 07:30 AM
07 here,Replaced leaking pinion seal at 4500 miles, whine between 50 and 60, now have 6500 miles
Washin
02-04-07, 09:51 AM
:ripped: :hijacked: :wtf:
ctsvett
02-04-07, 01:45 PM
06 and later come with beefier half shafts and the "improved" 06 rear end (a part that is put in all 04/05 replacements).
The suspension difference is only that they put the "cradle bushings" in at the factory.
Reed
Kadonny
02-05-07, 08:58 AM
Reed
I don't think that is right Reed. My 06 did not have the GM TSB bushings and the dealer told me that there was no way to insert the Spectre bushings becuase the cradle was redesigned a bit. James will know what they changed.
