View Full Version : Binder Laser Jammer Install
chrisalteregokelley@
01-29-07, 10:06 PM
Where should I install the Laser Jammer?
Binder.net
http://www.cadillacforums.com/forums/attachment.php?attachmentid=27212&stc=1&d=1170128822
http://www.cadillacforums.com/forums/attachment.php?attachmentid=27213&stc=1&d=1170128822
The package comes with either 2 or 4 sensors. I can put two below the Fog Lamps and two behind the mesh grill close to the headlights.
OR, I can put two below the Fog Lamps and one behind the mesh grill in the bottom center then one right above/below the rear plate.
What do you think?
Vdrenaline
01-29-07, 10:34 PM
Binder.net
What do you think?
The kit with 4 transmiiters is designed for 2 to be used in front and 2 in the rear.
The best place to mount the front ones on a V is to hang them from the flat plastic cover behind the upper mesh grill and in front of the radiator. Use 3M heavy Duty double sided tape to hanfg them. in 3 years, mine haven't moved at all. The metal grill on the V does not interfere with their effectiveness. I have been targeted at 80+ MPH and the laser operator did not get a reading untill I slowed down and turned off the transmitters! Love my blinder!
01-30-07, 12:29 AM
Replace Binder w/ Blinder, oops on the spelilng.
Thanks Vdenaline from CT for the input.
Vdrenaline
01-30-07, 11:09 PM
My pleasure Chris, happy jamming (and speeding)
01-31-07, 09:29 PM
Where did you put the rear sensors?
We're both in the Commercial RE Business. What aspect are you involved in. What's the prop value in CT?
Vdrenaline
01-31-07, 10:09 PM
Hi Chris,
I never installed the rear transmitters. They are still in the box but I saw a cool rear installation at the carwash this weekend on an RS4. One transmitter was mounted to the bottom of a license plate frame. It was pretty trick!
I am a commercial tenant rep real estate broker in Manhattan and also own some properties. Properity values in Greenwich where I live are hyper inflated.
Good luck with your Blinder!
