: will this fix the cts-v, are the part #'s the same?
1QUICKV
01-29-07, 09:37 PM
http://cgi.ebay.com/ebaymotors/LS1-LS2-LS6-NEW-CHEVY-CLUTCH-WITH-DUAL-MASS-FLYWHEEL_W0QQcmdZViewItemQQcategoryZ33730QQihZ018Q QitemZ280076610623QQrdZ1
I want to order a new clutch and flywheel to help the hard shifts and the clucth feel which fcuked up after one night the clutch went to the floor and i pumped it and it came back up. Is there anything i could tell the dealer to replace to get the fixed?
rgd
01-30-07, 02:10 AM
Might have a fix for that problem of yours. Mine was doing the same thing. Went to push the clutch in and it basically sucked to the floor. Had to pull it up with the toe of my foot and blablabla...
it might be as simple as bad oil. Mine was really ugly though!
What does the fluid in your clutch reservoir look like? If there is moisture in there or it has broken down due to heat and/or has become contaminated...bleed it! Mine was ugly dark with a little moisture in it due to my vented hood. I bled it and it is good as new. I'm still going to change it out with my cam soon but until then it's working again.
Never know this might be of help so I'm tossin it up.
I'm off~
rgd
Good luck
starfox86
01-30-07, 02:25 AM
they replaced my friends clutch under warrentee because it stuck...it was a defect in some of them the service manager said
CHP N-V
01-30-07, 02:34 AM
Isn't this the same problem 50 was having with his car...
1QUICKV
01-30-07, 07:50 AM
okay great, so what should i tell the dealer?
SBONES
01-30-07, 08:13 AM
under spirited driving my clutch stick's....fix it.:thumbsup:
1QUICKV
01-30-07, 08:47 AM
cool "SBONES" but is there a recall or something thats my question, because the rad is leaking again and right motor mount instead of the the right i replaced. so its going back to the dealer and i want to fix all this shit now.
