View Full Version : Dropping cradle - where's the other wiring?
eldorado1
03-15-04, 07:47 PM
Taken from another post:
"Do pull the battery,air intake tube, brake calipers(hang to the inner fenders),radiator(A/C condenser comes out with it),exhaust at rear of engine.wiring harness that goes to the computer(underdash) and end that goes to elect section on drivers side fender,struts at the top,steering shaft to rack coupler(it will seperate when you raise the body),disconnect A/C hoses ."
I can't seem to find out how to disconnect the driver's side wiring... What am I doing wrong? The ECM wiring was a breeze, but this stuff seems to be bolted down or something? Any ideas?
Lawrence
03-15-04, 09:47 PM
It's attached to the power center (fuse box). You have to seperate the power center and take part of it with the harness.
zonie77
03-15-04, 11:25 PM
It is bolted down. You're gonna have to pull some of the ends from the inner fender. i didn't get any pics of that end of the wiring.
I think it was obvious as you start taking it apart.
eldorado1
03-15-04, 11:30 PM
Thanks guys! Figured it out... I thought there was only one "harness" that connected the whole car... I didn't know there was a body one and a engine one... For those that care, there's a connector between the two that has a bolt in the middle on the driver's fender... part that, and you're done. Thanks again!
