View Full Version : 2000+ N* Info needed
befarrer
01-28-07, 12:10 PM
I am putting a 2002 or 2003 non VVT Northstar in an 86 Pontiac Fiero GT, 5-speed. The engine is in and running with an aftermarket ECM, but I need some information for the ECM.
The ECM is a Big Stuff 3, it is capable of running the stock 00+ coil on plug ignition and sequential fuel injection. But I need to know stuff like how many teeth are on the crank and cam reluctor wheel, the trigger angle of both, cam profiles, injector size, etc... The engine is from a Seville STS, and is the 300HP version.
The problem I am having is that it will not rev, or run good. I think it is a problem in the setup of the engine. Someone must have taken one of these engines apart so far. I can figure out the crank refrence angle, but I need to know how many pulses/rev it gets.
Thanks,
Ben.
submariner409
01-28-07, 12:25 PM
I'm not an ECM whiz, but I do know that the crank reluctor wheel (2002) has a strange set of unevenly spaced "teeth" which also vary in width.
CadillacSTS2003
01-28-07, 12:38 PM
ooo
00+ not best to work with
93-95 obd1 would of been better
96-99 egh easier...
00+ not fun
befarrer
01-28-07, 01:00 PM
Here is the ECM he is running:
http://force-efi.com/bigstuff.htm
The one on the bottom (GEN3 PRO SEFI)
wydopnthrtl
01-30-07, 12:53 PM
I wish I could help because this sounds like an awsome project!
I have an 01 eldo w/275hp motor that's driven daily. If there is any kind of lite weight info you might benifiet from? Just e-mail me and I'll look / take pics as best I can.
wydopnthrtl at yahoo
Rich
