View Full Version : 2005 CTS, Pioneer N2.. Fuse keeps blowing+battery keeps dying.
aky
01-23-07, 04:37 PM
Here's my problems, i really need some help to get this fixed...
1-Had the Pioneer N2 DVD Deck installed
2-battery died in car about 3 months later, battery was completely drained, and the ECM/TCM Fuses blew. Car was in Park, radio was on. Keys stuck in ignition
3-SAME AS ABOVE
4-Same as above but my car was in MOTION while this happened.
First 2 times, GM covered this under warrenty. They changed fuses and recharged battery and even replaced the battery. But this third time, they said it COULD my DVD Deck that was blowing the fuses. They didnt cover me. I took my vehicle back to the car audio place, they installed a POWER RELAY, and said it might help, but everything checks out on their install. From when i got this installed and til now, it's been about 9 months.
Does anyone know what this could be, i dont want to get stuck in the middle of the road monthly, i now carry extra fuses just in case
Is this the install, should of the installer put the Power Relay the first time, or is this a vehicle problem???
If anyone can help please let me know
thanks
2005 CTS
Pioneer N2
aky
06-04-07, 01:50 PM
bump ttt
CadillacSTS42005
06-05-07, 04:27 PM
ya they installed it and didnt connect a correct harness to maintain the data class 2 signal
aky
06-05-07, 05:35 PM
they didnt even use the GMOS harness, they used this one
http://www.installer.com/item/display_item.php?it=70-1784
right now each time i put a fuse in it blows instantly, any reason why, how can i fix this?
thanks
CadillacSTS42005
06-05-07, 05:56 PM
ROFL
1 that harness if for a VW not a Lac
and
2 that in NO way maintains the data serial
aky
06-05-07, 08:57 PM
ROFL
and
thats what i thought, what do i need then. a GMOS ??? Theres so many.
any reason why my fuse keeps blowing on me?
If i put the factory deck back in, would this fix my problems?
thanks
CadillacSTS42005
06-05-07, 09:19 PM
email metra
they will tell you which gmos you need
and yes the factory deck would solve it
aky
06-06-07, 12:48 PM
email metra
ive taken out the after market deck and same problem, fuse blows on contact.
ive yet to put in stock deck... might have to get the installer to do this for me, not sure how, it's a mess back there, with a harness shouldnt it be fairly easy? unplug harness and put stock deck back? i hope the installer didnt hack up all my stock wiring... :rolleyes:
CadillacSTS42005
06-06-07, 08:59 PM
it has to do with the data bus
without the factory radio or the gmos which dummys the system into thinking the factory radios connected it will prob continue to short
aky
06-07-07, 12:34 AM
ok thats good to know, ill have to put the factory deck back in for now
just a Q though, why did it work for about a year?
CadillacSTS42005
06-07-07, 07:54 AM
prob worked and then fried something maybe a wire in the install is touching a ground which seems likely...
aky
06-07-07, 05:17 PM
well im going 2 try and put the stock deck back... then if that works, ill get the GMOS.
any idea how to put stock deck back?
CadillacSTS42005
06-08-07, 05:13 PM
never done a cts yet to date
im an old FWD lac 32 pin master
my knowledge is very limited on CTS, STS, XLR and DTS
may wanna check with your forum on that
aky
06-08-07, 07:06 PM
ok the stock deck is back in and and stero works. car still doesnt turn over. keys still stuck in the ignition, any ideas/=?
CadillacSTS42005
06-08-07, 07:18 PM
d/c the battery
allow things to reset
you never mentioned the keys were stuck in the ignition...
aky
06-08-07, 10:26 PM
sorry yes the keys are stuck in the ignition.
the battery was disconnected the whole time the aftermarket deck was removed. then a fully charged battery was put in, and the fuse blew instantly.
