Destroyer
01-21-07, 05:57 PM
Just got new fillers for the rear tailights, how hard is it to change them?. Doesn't look like I need to remove the rear bumper. Hope it isn't that much of a PITA. Thanks.
| View Full Version : Changing rear tailight fillers on a '91 Destroyer 01-21-07, 05:57 PM Just got new fillers for the rear tailights, how hard is it to change them?. Doesn't look like I need to remove the rear bumper. Hope it isn't that much of a PITA. Thanks. 77CDV 01-21-07, 08:25 PM Not sure about 91, but for 77, you just remove the tail lights, then undo the bolts holding the fillers in place (scoot under the car, they're easy to see). I don't recall 91 being too different. It's kind of a tight work space, maybe an hour's work. Shouldn't be too much trouble. Good luck. Craig Destroyer 01-22-07, 09:34 AM Thats exactly what I thought I'd have to do but didn't want any surprises. Thanks man. drlowz 01-26-07, 02:03 AM I just changed them on my 81 brougham and the bumper had to be removed... KaddyKat 01-26-07, 08:45 AM which are better, the fiberglass kind or the abs plastic ones? Seems like the abs would be. Destroyer 01-26-07, 06:05 PM I think the ones I bought are the plastic ones. Much harder than the stock ones. I got one side done as I still have to paint the other side and it took a bit longer than I thought. The old one was much more flexible than the replacement and could be bent in to fit right. I had to loosen the tailight assembly to get the new harder one to fit but it worked out fine and I did not have to remove the bumper. Instead of taking them to a paint shop I was able to almost perfectly match the color with store bought spray cans. Came out nice and glossy too. Primered it, painted it and then shot it with a gloss coat. :thumbsup: | |
