Hammondsix
01-21-07, 10:55 AM
Im wondering wether or not my 1994 FWB has the air level ride, because if it does it is not working! Where is the compressor?
| View Full Version : Do all 93-96 Fleetwoods have Air suspension? Hammondsix 01-21-07, 10:55 AM Im wondering wether or not my 1994 FWB has the air level ride, because if it does it is not working! Where is the compressor? 90Brougham350 01-21-07, 11:30 AM Check the fuse under the dash first. The compressor on the 80-92's is on top of the driver's side wheel well near the firewall, it might be there in the 93-96's. Your car does have air suspension. caddycruiser 01-21-07, 11:44 AM All have air rear shocks and compressor, yes. The only difference throughout the years, I believe, is that the compressor is in the rear on '93s and in the front on '94-96s. Hammondsix 01-21-07, 01:22 PM where is my compressor then? In the wheel well? PAX side? i dont see it... Hammondsix 01-21-07, 08:28 PM anybody?? davidrap 01-21-07, 09:12 PM Hi, The compressor is on the driver's side infront on the lf wheel. Most easily accessed from under the car the front of the lf quarter panel. The fuse is the fuseblock under the hood on the passenger side. It is a green 30 amp big blade fuse. Best of luck, David Hammondsix 01-22-07, 07:53 AM Thanks i hope i can fix it. Otherwise its gonna be like 500+ dollars to buy a new one from the dealer. BCs71 01-22-07, 02:32 PM Compressor on a 94 is mounted on the framerail just behind the bumper on the driver's side. Behind the bumper, under the car, you should see some black plastic flat pieces (rain guards) that sit horizontally and held in place with springs and things. | |
