3rd Coast Balla
01-21-07, 03:19 AM
i was wondering what was good oil to put because i just changed mine in my car and i put syntetic castrol...is that good or is say regular castrol gtx better....just wondering
| View Full Version : What oil is best for a 97 deville 3rd Coast Balla 01-21-07, 03:19 AM i was wondering what was good oil to put because i just changed mine in my car and i put syntetic castrol...is that good or is say regular castrol gtx better....just wondering Flynn 01-21-07, 09:43 AM At the risk of starting another "Havoline" avalanche, I'd say you did just fine choosing Castrol synthetic. Dadillac 01-21-07, 11:10 AM What oil is best for a 97 deville New slippery kind. Don eldorado1 01-21-07, 11:30 AM Well since you asked, Rotella T Synthetic. StuJac 01-21-07, 11:41 AM I like walnut oil for pancakes. EcSTSatic 01-21-07, 11:46 AM Why ask after the fact? Go with it, you're fine - it's oil. If you really want to read about particular preferences then do a search. Ranger 01-21-07, 07:02 PM Here we go again. :hide: :horse: codewize 01-21-07, 09:37 PM Yeah just lock this thread. There's enough of this going on. Any name brand Synth is better than any Dyno oil, period. If you're not going to keep the car forever any good oil will do. Mods. lock this please. JohnnyO 01-25-07, 09:45 AM 10w-30 Havoline, Chevron, or Pennzoil. Valvoline Max Life is very good too. clarkz71 01-28-07, 06:20 PM Bottom line.... any API starburst certified oil, 5/30 in winter, 10/30 in summer. I use Mobil 1 10/30. Castrol synthetic is fine as long as it's 5/30 or 10/30 eldorado1 01-28-07, 06:29 PM http://www.cadillacforums.com/forums/northstar-performance-technical-discussion/74150-api-grades.html dkozloski 01-28-07, 08:35 PM Canola! submariner409 01-28-07, 09:19 PM :horse: Read the owner's manual and don't believe the snake oil claims. A "starburst" certified oil with the proper viscosity for your most normal temperature conditions will do just fine. Otherwise, hype is just more "American Idol" bullcrap. eldorado1 01-29-07, 12:10 AM For a 93-99, a "starburst" certified oil may not have enough high pressure anti-wear additives to keep your cams and lifters alive. (read: ZDDP) That can be corrected by adding the EOS. See above linked thread. | |
