: 06 srx- shifter lock, brake warning issue
zare6
01-19-07, 09:53 AM
My 06 srx v-6 has 4000 miles on it and last week started giving us problems. The first one is the shifter would not come out of park and no it wasn't torque locked, it happen 4 times and the only way we got into gear was by turning off the engine removing the key and then open the door then restart.
The second problem occurred at the same time , all the warning lights assocaited with brakes came on, abs, traction control,no brake warning and stablization. The weather at the time was very cold. Any ideas I took it to the dealer and they have no clue they said all the codes that should have been stored are gone.
TSS
01-19-07, 10:59 AM
Sure seems like a brake interlock issue to me. Car is not registering brake pedal being pushed.
zare6
01-19-07, 09:01 PM
Was able to retrieve 2 codes c0121[valve relay circut malfunction] and c0281[brake switch circuit] anybody know what these are and where the problem lies.
Bulletbling
06-15-15, 03:05 PM
I'm not purposely bringing up an old thread, but this is an answer to the question. C0121 indicates a valve relay circuit malfunction within the EBCM. The EBCM must be replaced or repaired. It can be repaired by ABSFIXER (Brandon who is the owner/fixer helped me fix this problem by resoldering the valve relay circuit). It triggered c0281 for me and now everything has been solved. No codes.
